dylanwaible Posted March 25, 2012 Share Posted March 25, 2012 Went down to O'Reilly's because the CEL was on. They pulled the codes and its got a misfire in cylinder 3 and 4. What good news right? besides something internal could it be something else? Link to comment Share on other sites More sharing options...
Frank B Posted March 25, 2012 Share Posted March 25, 2012 Ignition coil or plug wires would be my guess. Start with some new spark plugs and plug wires, it won't hurt it to tune it up. Link to comment Share on other sites More sharing options...
dylanwaible Posted March 25, 2012 Author Share Posted March 25, 2012 I have new NGK wires but I'll check the plugs and coil! Wouldn't it be nice if it was that simple? Link to comment Share on other sites More sharing options...
Byll Posted March 26, 2012 Share Posted March 26, 2012 Just had to have the coil changed on our daughter's '97 GT wagon. First thing that ever left her sit - in 125,000 miles. And it died in the driveway of our home. Convenient. Cheers. Byll Link to comment Share on other sites More sharing options...
silverone Posted March 26, 2012 Share Posted March 26, 2012 miss fires can also be an injector problem, or a vacume leak. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 27, 2012 Share Posted March 27, 2012 or bad carbon build up on valves. edit, looking to my left, that damn intercooler could not fit the front off that car any better. better then clothed porn. BNR18g on 93oct Link to comment Share on other sites More sharing options...
imfamousG Posted March 27, 2012 Share Posted March 27, 2012 im having the same problem and i cant figure it out either i too changed the plugs and wires and O2 sensors and check all the vacuums but still misfiring Link to comment Share on other sites More sharing options...
dylanwaible Posted March 27, 2012 Author Share Posted March 27, 2012 The check engine light blinks and keeps blinking and it can't accelerate for shit. Even when I floor it. Definitely not firing on all 4 cylinders. Then when the light stops blinking and is on solid it will run fine.. This went from happening once a month to once a week then when it happened two days in a row i brought it to a guy who does good work for cheap so I should know the diagnosis tomorrow Link to comment Share on other sites More sharing options...
silverone Posted March 27, 2012 Share Posted March 27, 2012 I'm not sure how big of a job this on a subie, but try swapping an injector with a cyl that's not missing to one that you know is , if the misfire follows the injector then you've got a bad injector. Could just be something as simple as a seal. Also take a can of carb cleaner spray it every where theres a vacume hose withthe engine running if your idle changes you've got a leak. Good luck! Link to comment Share on other sites More sharing options...
imfamousG Posted March 28, 2012 Share Posted March 28, 2012 Is it hard to change the ignition coil? And I don't think it's a vacuum leak how can I be sure? But if you could post what that guy says it might be that would be great:) Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 29, 2012 Share Posted March 29, 2012 It's easy to change your ignition coil. It's the black thing that your spark plugs connect to on top of your intake manifold. But do everything else everyone has told you first. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 29, 2012 I Donated Share Posted March 29, 2012 PlugsWiresCoilpackMass Air Flow SensorThrottle Position SensorIntake Manifold GasketCracked Intake ManifoldFuel InjectorsFuel PumpTiming Belt (jumped time)Camshaft Position SensorCrankshaft Position SensorValvesCracked HeadCracked BlockBlown Head GasketPison RingsIdle Air Control ValveFuel Filterthe list goes on. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
imfamousG Posted March 30, 2012 Share Posted March 30, 2012 Well then should I try and fix/change everything or just save the money and buy a JDM EJ25? Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 31, 2012 Share Posted March 31, 2012 The wiring is probably different on a JDM EJ25 so it might not be a plug and play swap. If you are unable to fix your current problem, it may not be prudent to attempt a whole engine swap. Try and fix it first and if you realize that your engine is toast, then do a swap. At the very least you will learn a lot. Link to comment Share on other sites More sharing options...
imfamousG Posted March 31, 2012 Share Posted March 31, 2012 Well I was just considering a swap since not to long ago I had a blown head(s) so I used this blue devil stuff and it's fixed.... For now so what do you think and how hard would it be to get the wires to work? Link to comment Share on other sites More sharing options...
