Stevo F Posted May 26, 2017 Share Posted May 26, 2017 I saw an ad for a '96 Legacy L wagon, little rust, 180K miles, recent timing belt change that I wouldn't mind getting for my son. The main issue is a vibration between 40- 60 MPH. That part makes me hesitate a little- what is the likelihood that the cause is minor (bad tire, or bent rim) vs. major (bad transmission). Also needs brakes, but that's not an issue. Link to comment Share on other sites More sharing options...
JF1GG29 Posted May 26, 2017 Share Posted May 26, 2017 Vibration can come from many different things: basically anything that can move. Where does the vibration come from? Do you feel it in the steering wheel? In the seat? The whole body of the car? Front/Rear? Constant or intermittent? The first thing you should do is to check the wheels and tires, ask when his last wheel balance was. Link to comment Share on other sites More sharing options...
Stevo F Posted May 26, 2017 Author Share Posted May 26, 2017 I asked the owner where the vibration is coming from from, but he hasn't replied back yet. Sounds like he lives near where I work, so maybe I'll get a chance to check it out later. Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 26, 2017 Share Posted May 26, 2017 Tires. either they are out of balance or worn by bad negative/positive camber Bent wheel is super noticeable. Link to comment Share on other sites More sharing options...
doublechaz Posted May 27, 2017 Share Posted May 27, 2017 Less likely than wheels/tires would be shot suspension parts. Tie rod ends, ball joints, control arm bushings, dampers. The 'only between 40-60' usually indicates an interaction with the pavement unless when it 'goes away' above 60 it's really vibrating too fast to resonate and changes from a shake to a sound. Link to comment Share on other sites More sharing options...
choover1101 Posted May 27, 2017 Share Posted May 27, 2017 My 96 GT had a bad vibration at 45+ it ended up being a sticking passenger front brake caliper and wheel bearing got toasted due to the heat. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Whopper Posted May 27, 2017 Share Posted May 27, 2017 If it comes from engine bay no go had a friend that blew apart his rods after a vibration. Link to comment Share on other sites More sharing options...
Stevo F Posted May 28, 2017 Author Share Posted May 28, 2017 The guy never responded back to my email anyway. Looking at a '95 sedan now. Link to comment Share on other sites More sharing options...
