OntarioGT Posted May 2, 2016 Share Posted May 2, 2016 Simple question, i know when I install the STI up-pipe it will throw a code because the egt sensor is removed, but will the car run and drive or go into a limp mode before I put the resistor in? Link to comment Share on other sites More sharing options...
Tuning Alliance Posted May 4, 2016 Share Posted May 4, 2016 Shouldn't go into limp. If you want, you can get an accessport and tune through us! -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
OntarioGT Posted May 6, 2016 Author Share Posted May 6, 2016 I will definitely consider it. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 6, 2016 Share Posted May 6, 2016 If you good with a lap top TA can also do e-tunes if you have the taxtrix cable. They can help with that too. I got my Invidia up/dn pipe from them back in 2010 also been on there tune 7 years now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
