Walkthough: JDM Spec. B Conversion
Well 1st off let me say thanks to Graham Ware at Japanparts. He was very patient with me every step of the way in getting my new front end.
Well.....
Lets get started.....
Total hours Including cleanup: 6 Hours...
Hours it should take you after reading this: 3-4...
Pro's: Looks awesome...Perfect Paint Match...I cant really complain about anything besides....
Con's:The main foam absorber didn't fit into the bumper without cutting about 3/4 of an inch off the top. Even with hat part cut its still a tight fit. (see picture 24) This could be the wrong part? Other then that...nothing besides making your own fog light brackets...
Before:
http://www.repsak.com/legacy/SpecB/specb_1.gif
After:
http://www.repsak.com/legacy/SpecB/specb_32.gif
WalkThrough:
Step 1: (This whole things really helps to have a lift, and to remove the front tires) Remove front bumper. You can easily find this in another section about how to clear your headlights...To make things easy I just put the Fenderwell's on the brakes.
http://www.repsak.com/legacy/SpecB/specb_2.gif
Step 2: There is a bracket that holds the bumper on below the headlight on each side. Remove them. It should be 4-5 bolts and a screw.
http://www.repsak.com/legacy/SpecB/specb_4.gif
Step 3: After You get the bolts on the side off, you will notice there are bolts on the bottom that are also holding the Main bumper beam in place. Remove those bolts to take the brackets completely off.
http://www.repsak.com/legacy/SpecB/specb_5.gif
http://www.repsak.com/legacy/SpecB/specb_6.gif
Step 4: As shown in the picture above take the lower bolts off the bumper beam. When they are all removed pull on the beam until it comes off. Should be fairly easy to do.
http://www.repsak.com/legacy/SpecB/specb_7.gif
Step 5: After that is off you will notice the lower air dam for the radiator. This is easily removed by 2 pop clips and 4 bolts.
http://www.repsak.com/legacy/SpecB/specb_8.gif
Step 6: Remove the lower bumper holder.
http://www.repsak.com/legacy/SpecB/specb_9.gif
Step 7 (Assembly): Attach the upper bumper brackets to the car. These are the ones that go under the headlights that you removed before. They go one using the same bolts, there are 2 lower bolts that aren't used on these brackets anymore.
http://www.repsak.com/legacy/SpecB/specb_10b.gif
http://www.repsak.com/legacy/SpecB/specb_10.gif
Step 8 (Assembly): Now attach the main JDM bumper beam to the car. Should bolt right into place. Remeber to leave the bolts loose and then tighten them to insure a good fit.
http://www.repsak.com/legacy/SpecB/specb_11.gif
Step 9 (Assembly): Now attach the JDM lower bumper beam to the car with the bolts/popclips shown.
http://www.repsak.com/legacy/SpecB/specb_13.gif
http://www.fcffhockey.com/kasper/legacy/SpecBConversion/specb_13.gif
Step 10 (Assembly): Attach the Styrofoam and you should have something that looks like this
http://www.repsak.com/legacy/SpecB/specb_14b.gif
http://www.repsak.com/legacy/SpecB/specb_14.gif
Step 11 (Assembly): Now get the JDM bumper and the new braces. Attach the braces using the old clips or the clips supplied. leave the top corners alone for now we will be putting bolts in there later.
http://www.repsak.com/legacy/SpecB/specb_15.gif
http://www.repsak.com/legacy/SpecB/specb_16.gif
http://www.repsak.com/legacy/SpecB/specb_17.gif
http://www.repsak.com/legacy/SpecB/specb_18.gif
Step 12 (Assembly): Before I forget you must change another bumper bracket on the side of the car. This is fairly simple, it is just a screw and it pops right in and out. Replace each side.
OLD
http://www.repsak.com/legacy/SpecB/specb_19.gif
New
http://www.repsak.com/legacy/SpecB/specb_20.gif
Step 13 (Foglight Assembly): Ah yes now for the biggest PITA...the fog light brackets. I first went to the hardware store and bought 12ga. sheet metal strips with the holes already drilled. I measured them up and started to bend, bend , and bend some more until everything lined up right. I then grinded the ends down and taped them off with foam tape I had laying around so it didnt cut any wires or my bumper. I made 4 lower brackets (2 short 2 long) for the bottom and I zip tied the top in place. I could of made a bracket for the top but that would of been a lot more time consuming. The end result is what you see here....
http://www.repsak.com/legacy/SpecB/specb_21.gif
http://www.repsak.com/legacy/SpecB/specb_22.gif
http://www.repsak.com/legacy/SpecB/specb_23.gif
Step 14 (Assembly): So I then went to put the bumper on and realized it wasnt fitting right at all. after a min or two I realized that the foam was larger then the hole in the bumper cover. So to fit that I took a knife and cut about 1/2 - 3/4 of an inch off the top part of the foam. put everything back togther and it fit a lot better, still a little tight thou. I might of gotten shipped a wrong part or I did something wrong, but there was no other way I could of gotten it on.
http://www.repsak.com/legacy/SpecB/specb_24.gif
Step 15 (Assembly): Finally I slid the bumper cover in place and after a little pushing and pulling it went right in.
http://www.repsak.com/legacy/SpecB/specb_25.gif
http://www.repsak.com/legacy/SpecB/specb_26.gif
Step 16 (Assembly): from here on out it was mainly putting everything back together. one problem I had was that the corner where the pop clip was supposed to go just didnt hold the bumper up high enough and left a gap...well we couldn't have that, so I took a nut and bolt and put it up in there and everything was nice and tight....just how I like it
http://www.repsak.com/legacy/SpecB/specb_27.gif
Step 17 (Assembly): I placed the pop clips back underneath the bumper cover and continued to mount up the splash shield again. The OEM splash shield had to be trimmed in 3 placed to ensure a good fit. One place was in the middle of the car right in front due to the fact the shield was hitting part of the bumper cover underneath. I cut about 1/4 of an inch off and it went right in. There were 2 sides that were hitting the lower JDM bumper beam. All you have to do is make 2 slits in each one and everything goes right in place ( sorry I don't have pictures of this)
http://www.repsak.com/legacy/SpecB/specb_28.gif
http://www.repsak.com/legacy/SpecB/specb_29.gif
Like I said in the beginning one of the problems is the inner fender well doesn't go flush with the bumper. (pictured below) this may cause damage to connections in the future with water/sand/salt getting in and corroding everything.
*Solution*
JDM Inner Fender wells fill the gap perfectly with no issues.
Japanparts.com now supplies the Inner Fender Wells with the Spec. B conversion kit so this shouldnt be an issue anymore. If you dont have them I would highly recommend them.
Part #: 107-024-S
It went fairly quickly, like I said the most time consuming was the fog light brackets.
http://www.repsak.com/legacy/SpecB/specb_30.gif
http://www.repsak.com/legacy/SpecB/specb_31.gif
-Craig
Hey, awesome walkthru! Thanks.
Could you clearify exactly what you mean by:
Like I said in the begining one of the problems is the inner fender well doesnt go flush with the bumper. (pictured below) this may cause damage to connections in the future with water/sand/salt getting in and corroding everything. I will have to make something to put in there eventually.
I don't see anything in the "picture below".
First off, kudos to you for doing this and posting up an awesome walkthrough.
I was surprised though that I don't find it as nice as CreoSTi's since GRP is way more teh sexay. It could very well just be the low, front-three quarter angle that just never seems to look right on the legacy. Post up some more pics from eye-level please!
It could also be the absence of the oval&wings which I would carry over (or just have gotten the jdm gt grille).
Please don't take my criticism personally... I just obsess about my car day&night and labor over future decisions. Although taste is subjective, there is no denying your execution was flawless!
yeah I was in debate on what grill to get, I'm never a fan of carbon fiber but I kinda like it. i was going to go OEM but then I'd want the outer chrome ring painted.
I just got a set of gold STI wheels today, I will put them on tommorow and post more pictures for you, will post in the pictures section tommorow night...
looks awesome, but i'm curious to know, does this have a provision to install the tow eyebolt like the USDM front end does?
its actually in the exacat location, even came with a cover to cover the hole.
  • 1 month later...
Is that the USDM front bumper beam or did you order the JDM bumper beam in addition to the Spec B front bumper?
Not to detract from an AWESOME writeup; and JapanParts says: Craig: thanks for the Thanks! And thanks for your patience with your Order
The Kit we supplied included the JDM Front Bumper back beam, energy absorbers and small hardware ( read: brackets/clips/bolts, tow hook cover ), we sell as a Set
At REPSAKS request we *also* supplied the JDM inner mudguards Pair as the USA ones had not been a perfect match with the Spec B bumper ( thanks for the Heads-Up on that, BTW, Craig )
The Spec B conversion Kit now also includes the inner mudguards Pair; our Part number
107-024-S (link )
http://www.japanparts.com/db/partslist.php?dealer=1&car=6&middlesmall=2%3A11&maker=5&volkey=107-024-S
FOG LIGHT Brackets; are part of the JDM foglight Kit, and cannot be supplied seperately to that, that's why the DIY on these, we can supply the JDM Foglight Kit for the Spec B bumper as a seperate Part
We can supply this Spec B conversion in several styles:
As an Unpainted Bumper Face, with ( or without ) the matching STi Front Lip
As a Painted Bumper face ( Factory paint, perfect Color match ) with/without STi Lip
As a complete "Bolt-on" conversion as REPSAK has documented here, Painted
Typically delivery takes 8 weeks to your Door; we ship ex-Tokyo to Long Beach CA, then onto any 48 States address from there
Grilles, both JDM Subaru, and Aftermarket, can be supplied , Back Bumpers also
Anyone wanting a quote, we'll advise "how much and how soon" and if you PM for a price we'll give you a Discount from our website pricing * we arrange all clearance, pay all Taxes into the USA and delivery fees *
Best!
Graham Ware
Export Manager
* Since 1996 *
  • 3 weeks later...
