ebo03 Posted January 12, 2015 Share Posted January 12, 2015 I had a Subimods harness that blew multiple fuses. As I recall from other threads this is common with their harness. So I bought a harness from AZP Installs about 2 years ago. On a couple of ocassions I have been gone for a few days with the car garaged and I came home to a dead battery. Dead as in the car wouldn't even attempt to crank. Just a click when turning over the key. I discovered with a multimeter that with the Hella relay powered up there are about 230 milliamps being drawn. Unhook the power source and it drops to the teens. Anybody with an AZP harness experiencing the same issue? Just wondering as it seems unlikely that I would have hooked it up incorrectly. Link to comment Share on other sites More sharing options...
Perscitus Posted January 13, 2015 Share Posted January 13, 2015 Ping AZP via PM or in the Tri-State forum. I have no experience with their harness but have seen a few horror stories with the Subispeed and Subimods v1 harness (they recently released a much better looking v2 harness). Personally I'm running a Lightwerkz harness and have had 0 issues with it since 2010. Had a second one installed on my kid brother's 2015 WRX in April. 0 issues thus far as well. Link to comment Share on other sites More sharing options...
ebo03 Posted January 13, 2015 Author Share Posted January 13, 2015 Great if you have a multimeter and could check it but if not could you see if the relay is warm to the touch? Mine is warm when the car is off. This just seems like a bizarre issue unless somehow the harness is incorrectly wired. Link to comment Share on other sites More sharing options...
Perscitus Posted January 13, 2015 Share Posted January 13, 2015 Great if you have a multimeter and could check it but if not could you see if the relay is warm to the touch? Mine is warm when the car is off. This just seems like a bizarre issue unless somehow the harness is incorrectly wired.I will do the warm to the touch test tomorrow and multimeter one Saturday. Link to comment Share on other sites More sharing options...
ebo03 Posted January 28, 2015 Author Share Posted January 28, 2015 Bought a Lightwerkz harness and issue is gone. Amazing that I've gone through two harnesses from two different vendors. The Subimods harness was blowing fuses and the AZP harness was killing relays. I noticed the Lightwerkz harness uses a different brand of relay than the others. Link to comment Share on other sites More sharing options...
Rutchard Posted January 29, 2015 Share Posted January 29, 2015 Wasn't there an issue a while back where Hella was including different relays with the horns? I don't remember if they were updated, defective, or just different... Providing a proper relay with the harness is a good CYA move on Lightwerkz part for sure. Link to comment Share on other sites More sharing options...
fredrik94087 Posted January 29, 2015 Share Posted January 29, 2015 I got my "kit" close to 1.5 years ago from subimods, I believe. Never had an issue, never had a dead battery with the car sitting for a week (and I am using a smaller lightweight battery) "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
AF_3C2 Posted January 29, 2015 Share Posted January 29, 2015 I bought my kit off Amazon- never sounded as loud as the first kit I had on my WRX, and then after a couple months they just stopped working all together. I suspect it is my relay- will need to get a new one if and when I decide to put them on my '14. Link to comment Share on other sites More sharing options...
acumenhokie Posted January 29, 2015 Share Posted January 29, 2015 I have the subimods harness. It gave me trouble with either grounding or relays early on but nothing lately. That said it could be drawing power even when turned off but I wouldn't know it because I have the car on a trickle charger. Link to comment Share on other sites More sharing options...
AF_3C2 Posted January 29, 2015 Share Posted January 29, 2015 I built my harness from some thick gauge (16g I think) speaker wire- probably not the best solution. Link to comment Share on other sites More sharing options...
ebo03 Posted January 29, 2015 Author Share Posted January 29, 2015 Looking back on it I would probably just make one instead of being lazy. I made one for my 06 STI and never had any issues. Link to comment Share on other sites More sharing options...
nstg8r Posted January 29, 2015 Share Posted January 29, 2015 I built my harness from some thick gauge (16g I think) speaker wire- probably not the best solution. As long as it's copper wire, and not just copper-coated aluminum (or just plain aluminum) you should be good. If it the Cu/Al stuff, go with 14awg or not at all. Personally, I only use speaker wire for low current solutions such as for LED lighting, but for anything 10A and up, I definitely go with primary wire. Another good choice would be to use an AC electrical extension cord rated for at least 15A. Link to comment Share on other sites More sharing options...
minuccims Posted January 30, 2015 Share Posted January 30, 2015 Subimods released a V2 harness. Looks much better. Never had a problem with the original harness for 95K miles through three winters. http://subimods.com/media/catalog/product/cache/1/image/fda82b21aeaf2fd22f2725bae7fc7ba8/r/s/rsz_mk3_0892_3.jpg http://subimods.com/subimods-hella-horn-bracket-and-wiring-harness-combo.html SubieSpeed has a harness now as well that will work for the 5th Gen: http://www.subispeed.com/media/catalog/product/cache/1/image/473x473/9df78eab33525d08d6e5fb8d27136e95/i/m/img_4252_2.jpg http://www.subispeed.com/2015-subaru-wrx/exterior/subispeed-hella-supertone-horn-wiring-harness#.VMrgzWjF__E Link to comment Share on other sites More sharing options...
orndog Posted January 30, 2015 Share Posted January 30, 2015 I need to do this on my new car. I miss my 'tones. Is there a write up to not do it ghetto like I did last time? Link to comment Share on other sites More sharing options...
fredrik94087 Posted January 30, 2015 Share Posted January 30, 2015 I need to do this on my new car. I miss my 'tones. Is there a write up to not do it ghetto like I did last time? Just get the harness from subimods and you are good to go. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Rutchard Posted January 30, 2015 Share Posted January 30, 2015 At least Subimods is sticking a fuse on their harnesses now. Before, they told me it didn't need a fuse, I threw that garbage away and wrote them off for good after that. If they were willing to potentially burn someone's car down, I don't want to do business with them. Link to comment Share on other sites More sharing options...
AF_3C2 Posted January 30, 2015 Share Posted January 30, 2015 On top of the harness, I bought a stick of Aluminum bar from Home Depot and created my own mounting bracket for the horns- so they were spread out a bit in the grill instead of close-set when only using the bracket on the horns. Link to comment Share on other sites More sharing options...
error Posted January 31, 2015 Share Posted January 31, 2015 Hella Supertones draw only 5.5A each - should be ok to run from the stock wiring, no? Link to comment Share on other sites More sharing options...
EdC Posted July 20, 2016 Share Posted July 20, 2016 Does anyone have a DIY install for Hella Horns on a 2011 GTL. Most interested on how and where they are mounted. Using existing fasteners or is additional mounting hardware needed? Ed Link to comment Share on other sites More sharing options...
foxrider28 Posted July 20, 2016 Share Posted July 20, 2016 Most people do the "bro-tie" bracket behind the grill. Either way you will most likely have to either make some custom mounts or find some random place to mount them both. You can just use 1 in the stock location if you'd like. Your best bet is to do a google image search of "5th gen legacy hella horns" you'll see what others have done. Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 21, 2016 Share Posted July 21, 2016 Does anyone have a DIY install for Hella Horns on a 2011 GTL. Most interested on how and where they are mounted. Using existing fasteners or is additional mounting hardware needed? Ed get the wiring harness and mounting bracket from whoever is selling them these days. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
EdC Posted July 21, 2016 Share Posted July 21, 2016 Guys thanks for the replies. How did you "fish" the cable into the relay compartment? ED Link to comment Share on other sites More sharing options...
EdC Posted July 21, 2016 Share Posted July 21, 2016 Okay, I see that custom cable as its own relay. Just go to either horn connection. Thanks Link to comment Share on other sites More sharing options...
