lil_z_33 Posted July 21, 2011 Share Posted July 21, 2011 So I had an accessport up that I was using until I ditched the stock turbo. I wanted my tunes on the accessport but due to some grounding issue, my car would shut off the turner's laptop and he was unable to tune it on the accessport. He ended up doing an OS tune instead. I recently noticed that there is Launch Control available on the accessport. Is it possible for my tuner to convert my OS to accessport without having to return entirely? Link to comment Share on other sites More sharing options...
rao Posted July 21, 2011 Share Posted July 21, 2011 It is possible, but not using the tuner that couldn't figure out how to use it before Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
lil_z_33 Posted July 21, 2011 Author Share Posted July 21, 2011 lol...he knew what he was doing...except under boost an engine ground was coming loose and shutting the car off as well as the laptop...for someone reason the same thing did not happen when opensource tuning... how is it possible to move the map over from opensource to cobb? Link to comment Share on other sites More sharing options...
Th3Franz Posted July 22, 2011 Share Posted July 22, 2011 You can run launch control on Open Source. Just get tiny wrex's patch. I have it enabled on my car and it works fine. I use it basically only as a 2 step. Barely hold the throttle to hold my revs. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
lil_z_33 Posted July 23, 2011 Author Share Posted July 23, 2011 where can one find this patch? Link to comment Share on other sites More sharing options...
Th3Franz Posted July 23, 2011 Share Posted July 23, 2011 their store is down for some reason. You need to get the patch that matches your ECU ID tinywrex.x10hosting.com/online/ -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
