InvisibleFrisbee Posted December 24, 2012 Share Posted December 24, 2012 I picked up a 2008 Spec.B and have enjoyed driving it the last couple of days. Onto the Mod Questions....maybe they're not typical. I want to SCCA Solo (autocross) the car in it's stock D class. I could go into the long version if people want to hear it, but at this point I'll give this brief information. I will use this as a daily driver and my kids will start driving it in about 4 years. I want to stay in the stock class. I've been told that the car may be more competitive in some other classes, but I want to stick to stock, keep my A/C (street modified allows removal of this), and keep the power where it's at. So, what modifications should I look at doing? What aftermarket (lighter) wheels are available in 18x7? I've done some reading at this point and it looks like I'll be keeping the stock intake, but what I haven't seen made clear is if there are gains to be made with a K&N style filter, or if I'm perfectly fine if the previous owner was putting in a wal-mart paper filter. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2012 Share Posted December 24, 2012 Give Mike at AZPinstalls.com a email. They race these cars. He'll have lots of free info and good products you can buy from him. My 05 Wagon has a Perrin panel filter since Aug 04 I use the K&N cleaning kit on it once a year. Welcome to the forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iNVAR Posted December 24, 2012 Share Posted December 24, 2012 Lighter wheels? Volk CE28N in 18x7.5 are light as hell but will put a huge hole in your wallet unless you find a used set. I'm going to unload mine in a bit, but 2 need repair (bent) so I'll likely let them go for super, super cheap so I don't have to deal with the hassle. They weigh about 14.5 lbs each. I don't think anything in this size weighs less. They're forged aluminum. Don't bother with intake. There won't be any gains to be made, and possibly only harm to be done. Read some of the stickies and do some searching. Stick to a paper failter. Welcome to the forum. Link to comment Share on other sites More sharing options...
lee07 Posted December 24, 2012 Share Posted December 24, 2012 Stage 1, a ecu reflash, that's still stock to me or better tire's Link to comment Share on other sites More sharing options...
InvisibleFrisbee Posted December 24, 2012 Author Share Posted December 24, 2012 Lighter wheels? Volk CE28N in 18x7.5 are light as hell but will put a huge hole in your wallet unless you find a used set. SCCA rules to stay stock I have to stay with an OEM size wheel. that means 18x7 not 18x7.5. Or the stock size off of any other Legacy from 2008. I think the regular Gt used 17x7 wheels, but not 100% sure on that. Don't bother with intake. There won't be any gains to be made, and possibly only harm to be done. Read some of the stickies and do some searching. Stick to a paper failter. Welcome to the forum. So I've read "stick to a paper filter" in a lot of places...but is any cheap paper filter from the auto parts store good enough? or are there gains from a high flow style filter? Stage 1, a ecu reflash, that's still stock to me or better tire's ECU changes are not stock by SCCA rules. Link to comment Share on other sites More sharing options...
iNVAR Posted December 24, 2012 Share Posted December 24, 2012 Ah, didn't realize you had to stay with stock width too, doh. Yeah, regular LGT is 17x7 stock. No gains from a high flow air filter or anything like that... certainly not at stock levels. Autoparts stores should be just fine. I use a stock Subaru paper filter personally. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2012 Share Posted December 24, 2012 If your going to be driving the car hard, your going to want to get a custom Tune. There is a flaw in the OEM MAP that can cause burnt valves and problems with #2 and 4 pistons. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iNVAR Posted December 24, 2012 Share Posted December 24, 2012 But that throws him out of stock class, doh! Personally, I'd rather get the tune and get thrown out of stock, than to not get the tune, have a slower car, and worry about valves and pistons going. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2012 Share Posted December 24, 2012 If the tune is stock not for HP gain but durability, how would they ever know ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AkumaMax Posted December 24, 2012 Share Posted December 24, 2012 Is this a trick topic? You bought a SpecB everything is done. Put it up against any car and it will destroy it! Link to comment Share on other sites More sharing options...
iNVAR Posted December 24, 2012 Share Posted December 24, 2012 If the tune is stock not for HP gain but durability, how would they ever know ? The OP will know. Cheater! Link to comment Share on other sites More sharing options...
InvisibleFrisbee Posted December 27, 2012 Author Share Posted December 27, 2012 If your going to be driving the car hard, your going to want to get a custom Tune. There is a flaw in the OEM MAP that can cause burnt valves and problems with #2 and 4 pistons. Can you point me to more information on this OEM tune problem. would like to know more information about the circumstances under which this can appear? Is a 50 second autocross run going to cause a problem, or is the real problem if I start doing 20-30 minute sessions of tracking the car? Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 28, 2012 Share Posted December 28, 2012 Does the Cobb tune the problems out? My car has 70k+ miles on it and I'm not too sure of its history, should I be concerned my valves are bad? ( sorry for hi-jacking) Link to comment Share on other sites More sharing options...
wpgspecb Posted April 8, 2013 Share Posted April 8, 2013 Does the Cobb tune the problems out? My car has 70k+ miles on it and I'm not too sure of its history, should I be concerned my valves are bad? ( sorry for hi-jacking) you can get a compression and leak down test to determine that. i have 70,000km on stage 2 cobb ots map, with no issues. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2013 Share Posted April 8, 2013 Can you point me to more information on this OEM tune problem. would like to know more information about the circumstances under which this can appear? Is a 50 second autocross run going to cause a problem, or is the real problem if I start doing 20-30 minute sessions of tracking the car? Just saw this again. Here, same issue in the 4th gen's. http://legacygt.com/forums/showthread.php/dangerous-cylinder-trims-5th-gen-lgts-193842.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2013 Share Posted April 8, 2013 Does the Cobb tune the problems out? My car has 70k+ miles on it and I'm not too sure of its history, should I be concerned my valves are bad? ( sorry for hi-jacking) Cobb is ok, I was on it a 8000 miles, my valve are great when the machine shop redid the heads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted April 8, 2013 I Donated Share Posted April 8, 2013 I believe a custom tune is fine, as long as boost levels are not altered. I don't think the SCCA rules say anything about changing timing or AFRs? Could be wrong, though. Link to comment Share on other sites More sharing options...
