Altezza Tail Lights for Legacy???
  • Replies 66
  • Created
  • Last Reply
^^^ I heard this can also be caused by using the wrong brand of oil as well as leaving your scoop uncovered when going through the car wash?????
Indeed. Your car does have a warning system for this though. In your gauge cluster, if you see the odometer show the message "Ill 1" or "Ill 3", you should really look into replacing the intercooler. If you ever see "Ill 5", or the dreaded "Ill 6", immediately pull over! A soaptercooler explosion is imminent!
:orly::spin::orly:
So it sounds like I should switch to a full blend of Mobile 1, Castrol GTX and Royal Purple with the NOS additive that I found in the cooler at Kum&Go and then completely seal my TMIC in carbon fiber and also run a FMIC but mount it in my trunk to be safe..... what kind of whp could I expect with that set up?
