slonez Posted April 25, 2013 Share Posted April 25, 2013 After a recent track session, I think I would like to be able to adjust the rear camber. I know Whiteline has a product for this: http://www.whiteline.com.au/product_detail4.php?part_number=KTA124 Are there any other product that enable rear camber adjustment? Link to comment Share on other sites More sharing options...
notthesnail Posted April 25, 2013 Share Posted April 25, 2013 http://www.whiteline.com.au/product_detail4.php?part_number=KCA399 Link to comment Share on other sites More sharing options...
scoobyscoodle Posted April 25, 2013 Share Posted April 25, 2013 If you track the car relatively frequently I'd highly recommend the set of 4 lateral links you listed above. You will love them. They really stiffen up the rear by drastically reducing deflection in turns, and give you more camber/toe adjustment than you'd ever need. Link to comment Share on other sites More sharing options...
slonez Posted April 29, 2013 Author Share Posted April 29, 2013 Thanks for the info. Found something interesting: http://hardrace.com/products.asp?strClass1=9&strClass2=66&strClass3=122 Link to comment Share on other sites More sharing options...
brawline Posted April 29, 2013 Share Posted April 29, 2013 check out megan racing they make camber as well as lateral arms as well so you can get the toe adjusted to 0 since the factory toe is impossible to 0 out when lowering. Link to comment Share on other sites More sharing options...
quick4dr Posted April 29, 2013 Share Posted April 29, 2013 love my whiteline toe arm, will be installing megan camber kit shortly after Megan replaces the original ones they sent me because they were damaged. after install Ill post pics and reviews second set came damaged as well, after dispute with vendor/ megan/ and master card i got my money back. will eventually just buy the remaining white line suspension parts. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted April 29, 2013 Share Posted April 29, 2013 Personally I'd stick with WL. They are an awesome company to work with, with customer service that is above and beyond. Dependable, stout products FTW. Link to comment Share on other sites More sharing options...
