LGT center bore vs WRX center bore
boostsr20
Aren't the LGT and the 04 WRX the same? I am looking at tirerack's site scratching my head trying to figure out why they list the Kosei K1TS for the WRX but not the LGT. Its 18x7.5 with a +50mm offset. This should fit perfectly on the LGT too, shouldn't it?
EDIT: 56.1mm is the center bore for both, correct?
Correct on the center bore.
The reason why they listed for the WRX and not the GT is because TireRack is VERY conservative with the fitment issues with their cars. As odd as it may sound, but a 18x7.5 with a +50mm offset AND add a tire on there (which can vary in size anyways) could possibly have rubbing issues on the spring perch side of things (hence they have 18x8 SSR with +51mm offset instead that would fit with a 225/40/18 that they suggest).
Keefe
Keefe
