BoxerLove Posted October 13, 2014 Share Posted October 13, 2014 So ive done some searching, and cant really find much on our cars with the 2nd cat deleted. (Waits for link to be posted of thread i didnt find ) My car threw a P0420 the other day randomly after i literally just replaced the Fuel filter, PCV valve, Trans fluid+filter, Engine oil+filter, Center diff fluid, NGK V power spark plugs, Cleaned the throttle body, did a Chevron fuel system cleaner (on sale 2 for $8) and did a seafoam through the vac line on intake to clean the carbon out She sure does run like a new car, much smoother. Of course after i do all the work it throws a P0420. Right now the exhaust setup is Borla header to stock cats , res delete to ebay muffler. Honestly sounds good, very deep and lots of rumble. But not very loud at all. How much louder would a 2nd cat delete make the car? Any performance value to the cat delete? I may even do a Tsudo high flow catted midpipe if i can get a good deal on one. Link to comment Share on other sites More sharing options...
johnegg Posted October 13, 2014 Share Posted October 13, 2014 deleting the second cat will not get rid of the p0420. typiaclly this is an o2 problem. the front o2 sensor should very high quality, subaru or better. the rear o2 can be generic, it just check to see if the cats are there and working. but read this first: P0420 Diag - Subaru Outback - Subaru Outback Forums Link to comment Share on other sites More sharing options...
Zues Marine Posted October 14, 2014 Share Posted October 14, 2014 the link above may mention it, you could also attempt the non-fouler/spacer method if all else fails: http://www.ultimatesubaru.org/forum/topic/113966-how-i-fixed-my-fing-420-code/page-2 Link to comment Share on other sites More sharing options...
Bassnectar Posted October 19, 2014 Share Posted October 19, 2014 no performance improvement from deleting the rear cat.. Fouler should get rid of code. But I have tried the trick on a Mazda that had been misfiring for weeks. the cat was too far gone for the trick to work. I think your Seafoam treatment may have overheated the front cat. but try the foulers first as there 5 bucks. Link to comment Share on other sites More sharing options...
