loc Posted April 2, 2008 Share Posted April 2, 2008 I'm in St. Charles, IL. I ordered some Rallitek springs for my 07 GT, I should be getting them on friday. I'm looking for a shop to have them installed. I know you guys are pretty knowledgable about this. I probably only should pay $500 at the most with an alignment right. Thanks for you help. Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 2, 2008 Share Posted April 2, 2008 Around 450 would be good, 500 would be pushing it. - Andrew Link to comment Share on other sites More sharing options...
Scrambles Posted April 3, 2008 Share Posted April 3, 2008 I'm in St. Charles, IL. I ordered some Rallitek springs for my 07 GT, I should be getting them on friday. I'm looking for a shop to have them installed. I know you guys are pretty knowledgable about this. I probably only should pay $500 at the most with an alignment right. Thanks for you help. I know this isn't what you're thinking right now, but is it completely out the question to do it yourself? I just installed coilovers on my wagon using a friend's tools in his driveway, and I have done ZERO work on cars before, I've never even changed my own oil. Sure, it took me a whole day, but I learned a lot and saved hundreds of dollars. Rent a spring compressor from autozone and buy a few wrenches, and all the information you need is elsewhere on these forums. Link to comment Share on other sites More sharing options...
TPLGT Posted April 3, 2008 Share Posted April 3, 2008 My input...I have an 06 and attempted to install my Swifts....I had SERIOUS issue removing the rear strut bolts!! Holy Shit! Soooo bad we bagged it and I paid to have it done....do a search on spring installs that may change things... A shop should not charge you more than 4 hrs. labor.... Rehab is for quitters. Link to comment Share on other sites More sharing options...
Scrambles Posted April 3, 2008 Share Posted April 3, 2008 My input...I have an 06 and attempted to install my Swifts....I had SERIOUS issue removing the rear strut bolts!! Holy Shit! Soooo bad we bagged it and I paid to have it done....do a search on spring installs that may change things... A shop should not charge you more than 4 hrs. labor.... They certainly are on there tight, I used a 2' socket wrench to break the nut loose and then hammered a wrench around, bracing the bolt head from rotating with another wrench against a block of wood. There are only two of them though. 4 hours of labor is insane, with air tools and a lift this could be done in less than an hour by one experienced person. Link to comment Share on other sites More sharing options...
whitetiger Posted April 3, 2008 Share Posted April 3, 2008 take me less than an hour to do 4 springs on jack stands with air tools. Link to comment Share on other sites More sharing options...
SunburnNYC Posted April 3, 2008 Share Posted April 3, 2008 take me less than an hour to do 4 springs on jack stands with air tools. because your the Subaru Master! *I'm sure working at the dealer might contribute a bit to your speedy work! I could do it in about 1 1/2 hours Link to comment Share on other sites More sharing options...
whitetiger Posted April 3, 2008 Share Posted April 3, 2008 not really. aside from the tight bolts one might encounter doing the install, the lgt struts are some of the easiest ones ive enver done. in fact, if you can jack up the car up reasonably high, you can take the rear struts out easily without even taking off the rear wheels. Link to comment Share on other sites More sharing options...
SunburnNYC Posted April 3, 2008 Share Posted April 3, 2008 not really. aside from the tight bolts one might encounter doing the install, the lgt struts are some of the easiest ones ive enver done. in fact, if you can jack up the car up reasonably high, you can take the rear struts out easily without even taking off the rear wheels. yeah the MKIII golf and Jetta are like that too... Link to comment Share on other sites More sharing options...
zmarko Posted April 3, 2008 Share Posted April 3, 2008 You could read through this thread and see if it's something you could tackle yourself. Link to comment Share on other sites More sharing options...
FourMoBro Posted April 3, 2008 Share Posted April 3, 2008 rear bolts come off easy, no air tools required: 1. soak with liquid wrench 2. attach wrench 3. attach jack handle, or sumthin else to give length 4. jack up on the extension break loose in no time. Link to comment Share on other sites More sharing options...
loc Posted April 3, 2008 Author Share Posted April 3, 2008 I found a place in St. Charles. Street Style.Charging me 300-350 with an alignment not bad. Made an appointment for this monday. Link to comment Share on other sites More sharing options...
