Psydriver Posted January 8, 2015 Share Posted January 8, 2015 Hey everyone, I have an issue with my cruise control and I'm curious as to if anyone else has had this problem and how to fix it. After rebuilding the engine and replacing the TGV sensors everything seems to be in great working condition except for when cruise is engaged. Basically, what we have found while watching it through the scan tool is that the TPS is hunting for its location as soon as the cruise control is engaged. We road tested it with me holding steady on the throttle and it didn't have an issue but as soon as Cruise was set it begins to hunt for a location and pluses. Its not a horrible thing other than the feeling but after researching it in the books we cannot find any issue stated or a specific repair procedure. I'm trying to avoid going back to the a Dealership with this problem, but with the equipment we have at our shop we cannot determine the problem. Any info on this subject would be greatly appreciated Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted January 8, 2015 Share Posted January 8, 2015 I had a surging issue after rebuild. A vac line had come loose. I would triple check them or look for leaks. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2015 Share Posted January 9, 2015 Have you had any wheel bearing changed lately? Link to comment Share on other sites More sharing options...
Psydriver Posted January 9, 2015 Author Share Posted January 9, 2015 No wheel bearings are all still the same. I thought that the new drive line would help since the u-joint broke in the original one and it didn't make a difference. I will definitely triple check my vacuum lines. Link to comment Share on other sites More sharing options...
cartman Posted January 12, 2015 Share Posted January 12, 2015 Have you had any wheel bearing changed lately? I have and have experienced same issue. Please explain how the wheel bearing and cc are related. Thanks. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 12, 2015 Share Posted January 12, 2015 I have and have experienced same issue. Please explain how the wheel bearing and cc are related. Thanks. There is a magnetic strip on the back of the wheel bearing. The abs sensor (on each wheel) uses this magnetic strip to do its job. There are a few instances where the abs sensor is not working well with aftermarket wheel bearings, thereby affecting cruise control behavior. Link to comment Share on other sites More sharing options...
