Heffernan Posted November 19, 2015 Share Posted November 19, 2015 For the better part of the last 6-8 months, I’ve been dealing with a loud and very frustrating (what I believe to be a) heat shield rattle coming from my 2008 NA Outback. I’ve had the shop I take my car to look at it twice already. Trying to locate the exact area it’s coming from (not obvious), even tig welding it in a few places, with no luck. The sound usually comes back a week or 2 later. Cold starts are the worst and it’s even prevalent when shifting from 1-2, 2-3 and sometime higher depending on the RPMs (the higher they are the more likely I’ll hear it.) I guess my question is, if it’s not the heat shield around the header, what else could it be? It sounds like it’s coming directly under the engine. My other question is, if I can’t remedy the situation and I stuck with just replacing the header altogether? Hoping to hear some opinions on this. Thanks. Link to comment Share on other sites More sharing options...
Captain Ned Posted November 19, 2015 Share Posted November 19, 2015 Usual way of fixing heat shields & their rattles is to use a hose clamp to tie it tighter to the exhaust or just rip the damn thing off. Link to comment Share on other sites More sharing options...
Heffernan Posted November 19, 2015 Author Share Posted November 19, 2015 My next step was to just take them off but wasn't sure if they were any absolute necessity. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 19, 2015 Share Posted November 19, 2015 Honda strap them... Link to comment Share on other sites More sharing options...
Heffernan Posted November 20, 2015 Author Share Posted November 20, 2015 Honda strap them... I'm not a regular in the Honda game... but it sounds ghetto Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2015 Share Posted November 20, 2015 Remove them. I have used DEI heat wrap as best I can to replace the heat shields. I removed the big over the mid pipe years ago. You don't need it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Heffernan Posted November 20, 2015 Author Share Posted November 20, 2015 Thanks for the input. Sounds like the way to go. Link to comment Share on other sites More sharing options...
Captain Ned Posted November 20, 2015 Share Posted November 20, 2015 I'm not a regular in the Honda game... but it sounds ghetto It's the hose clamp routine. Learned it with my '97 Civic EX way back when. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 20, 2015 Share Posted November 20, 2015 Same issue here with my Legacy. Damned if I can find which ones are loose and rattling when the engine is cold. I don't think its a good idea to remove them. If the exhaust manifold is very hot and water gets splashed up from the road I do believe they are much more likely to crack. Link to comment Share on other sites More sharing options...
cerbomark Posted November 21, 2015 Share Posted November 21, 2015 Had same thing on an 08 outback.... I cut it off. Case closed. Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted November 22, 2015 Share Posted November 22, 2015 Check the shield on the 2nd cat- that was making me nuts for a week. A hose clamp fixed it for me. If all else fails, start it cold and put your hand on each section of shielding, top and bottom. Watch for turning belts/pulleys, you probably need all your fingers. Link to comment Share on other sites More sharing options...
Heffernan Posted January 6, 2016 Author Share Posted January 6, 2016 Check the shield on the 2nd cat- that was making me nuts for a week. A hose clamp fixed it for me. Yup, that what finally fixed it for me. I put a hose clamp on the front of that shield and another just in front of that on the header shield. Only cost $3 of fix as well. Link to comment Share on other sites More sharing options...
NavigatorsLegacy Posted August 6, 2017 Share Posted August 6, 2017 I'm in bad shape...an intermittent tin can sounding rattle has got more frequent and louder at lower RPMs and sometimes when i start it up on a very hot day...pls advise as it is the only thing I dislike about my subie. Sent from my LGLS992 using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted August 6, 2017 Share Posted August 6, 2017 Depends on what is causing the rattle. It's a little ghetto, but on my car I had a rattle coming from the rear catalytic converter heat shields. Drilled a small hole in the heat shield, and put a small sheet metal screw in there until it made contact with the pipe to brace the shield. Honestly, I actually got this idea from what a subaru tech did to my car a year earlier. I asked them to see if they could fix my heat shield rattle in another spot, and that's what the tech did. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 6, 2017 Share Posted August 6, 2017 Depends on what is causing the rattle. It's a little ghetto, but on my car I had a rattle coming from the rear catalytic converter heat shields. Drilled a small hole in the heat shield, and put a small sheet metal screw in there until it made contact with the pipe to brace the shield. Honestly, I actually got this idea from what a subaru tech did to my car a year earlier. I asked them to see if they could fix my heat shield rattle in another spot, and that's what the tech did. What he said ^^^ Self tapping screws work the best when the whole shield is loose around the pipe but still intact. Link to comment Share on other sites More sharing options...
