bony19 Posted May 1, 2014 Share Posted May 1, 2014 Hi All I just recently purchased a lgt 05 with a bad turbo. I just got a new turbo for the car and also catless up and aftermarket catback. Debatting if I get a aftermarket dp ,either catted or catless dp will I need a tune for the car? And also any infor will I need to check to make the car more reliable? thanks Link to comment Share on other sites More sharing options...
forcedinductiongt Posted May 1, 2014 Share Posted May 1, 2014 If you got a cat back and an up pipe...you might as well get the dp amd go stage 2 Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 1, 2014 Share Posted May 1, 2014 You absolutely need to tune the car with a DP, cannot run the oem map. What turbo did you put in? If it's anything other than a vf40/46, you absolutely need to tune for that as well. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 1, 2014 Mega Users Share Posted May 1, 2014 Why are you debatting the car? Is there an infestation? Have you tried keeping the windows...up? Link to comment Share on other sites More sharing options...
Brett Posted May 1, 2014 Share Posted May 1, 2014 he means that the bats are staying in until he gets a dp. Link to comment Share on other sites More sharing options...
ras06LGT Posted May 1, 2014 Share Posted May 1, 2014 Before throwing a new turbo on there make sure you inspect the oil system for metal debris (pan, cooler, banjo filters if you still have them), otherwise you could end up blowing the new turbo and/or engine very quickly. Link to comment Share on other sites More sharing options...
bony19 Posted May 1, 2014 Author Share Posted May 1, 2014 I always assume that if u buy a catted dp u didnt have to get it tune?. ..I brought both vf40 n vf 52. Because of the money factor for tunning and buying a ap was costing me $$$. I just wanted best bang for your the budget . Any best subjection for saving $$$ for more hp? Thanks Link to comment Share on other sites More sharing options...
JermTheElf Posted May 1, 2014 Share Posted May 1, 2014 lol Link to comment Share on other sites More sharing options...
robinlsb Posted May 1, 2014 Share Posted May 1, 2014 I always assume that if u buy a catted dp u didnt have to get it tune?. ..I brought both vf40 n vf 52. Because of the money factor for tunning and buying a ap was costing me $$$. I just wanted best bang for your the budget . Any best subjection for saving $$$ for more hp? Thanks It depends on the DP. If it is a free flow, you need a tune. And if it's not a free flow, you are losing tons of HP, even with a better turbo. The major restriction is in the stock, non free flow DP. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Drift Motion Posted May 1, 2014 Share Posted May 1, 2014 oh...THAT "DP" LOLLL Link to comment Share on other sites More sharing options...
PtPixel Posted May 1, 2014 Share Posted May 1, 2014 I always assume that if u buy a catted dp u didnt have to get it tune?. ..I brought both vf40 n vf 52. Because of the money factor for tunning and buying a ap was costing me $$$. I just wanted best bang for your the budget . Wait, what? You're concerned about the cost of getting it tuned, but you bought two different turbos?? Any best subjection for saving $$$ for more hp? Thanks I think that's an oxymoron Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 2, 2014 Share Posted May 2, 2014 The stock DP's restrictions are certainly not due only to the cats. And even so, any aftermarket DP that has a cat is going to have a high flow, race style cat which really has no similarities to the oem ones in terms of density and flow. Not to mention the fact that the real restriction in the oem DP is that plate that sits right in front of the iwg. ANY aftermarket DP will do away with that plate. The bottom line is ANY aftermarket DP will require a tune. Period. 3", 2.5", catted, catless, shorty, whatever, you need a tune. Also, you CANNOT run the vf52 without a tune, no way, no how. It flows a LOT more air than the vf40. If you cannot afford to tune the car, you cannot afford to mod the car. Doesn't mean you need to buy an AP, but if you're running a non-oem turbo and a DP, you need a custom tune. Link to comment Share on other sites More sharing options...
bony19 Posted May 2, 2014 Author Share Posted May 2, 2014 Thanks all for everyone input. I know that when I install vf52 it an automatic that I need a tune. But if I keep it stock I be safe. The reason I ask was I used to have 02 wrx wagon. I keep the stock turbo, but I upgraded a catted dp and catless up and the whole cat back without any tunes. So this why I ask peeps in the forum for advise because I never have lgt before and never expect it such a high maintenance compare to my old bugeyes. Link to comment Share on other sites More sharing options...
ras06LGT Posted May 2, 2014 Share Posted May 2, 2014 You should have tune the '02 WRX as well. Link to comment Share on other sites More sharing options...
evildriver Posted May 2, 2014 Share Posted May 2, 2014 may i ask the reason you no longer have the wrx? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 2, 2014 Mega Users Share Posted May 2, 2014 I'm guessing piston issues... Link to comment Share on other sites More sharing options...
bony19 Posted May 3, 2014 Author Share Posted May 3, 2014 Car was total because some idiot hit me from the back. but no issue issue with the piston or engine. It ran strong with no hicup. This why I figure if i got a catted dp it wont show any code on the engine. On the wrx wagon I just have aftermaket inlet, dp, up, intake. and it pull strong. So I dont know why everyone here is flaming me about having tune. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 3, 2014 Mega Users Share Posted May 3, 2014 Cuz you're gonna blow shit up. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 3, 2014 Share Posted May 3, 2014 Even if the car did run alright, which I doubt, why would you spend money on all those parts and not tune for them? Why people insist on bolting on performance parts without tuning for those parts is beyond me. Do people really think that the tune doesn't make a difference?!? Link to comment Share on other sites More sharing options...
