Bruce Riggins Posted August 5, 2010 Share Posted August 5, 2010 My right headlight is out. The instruction book says to disconnect the electrical connector. I can't get it out by pulling straight out nor can I turn it. How does this electrical connector come off? Does anyone know? Link to comment Share on other sites More sharing options...
uprising Posted August 5, 2010 Share Posted August 5, 2010 its supposed to come right off by pulling it, could be just really stuck in there Link to comment Share on other sites More sharing options...
amp27 Posted August 5, 2010 Share Posted August 5, 2010 really. i thought i was doing it wrong... mine is stuck to. Link to comment Share on other sites More sharing options...
LiCelsior Posted August 5, 2010 Share Posted August 5, 2010 try to get a flathead between the bulb and the connected and pry it slowly. Link to comment Share on other sites More sharing options...
kaz98gt Posted August 5, 2010 Share Posted August 5, 2010 ^^ this, but be very careful you don't break the tab. Mine was stuck, but I just worked at it wiggling it back and forth and pulling slowly. Tedious, but it should come off at some point. Link to comment Share on other sites More sharing options...
worknlikeadog Posted August 5, 2010 Share Posted August 5, 2010 wiggle wiggle wiggle Link to comment Share on other sites More sharing options...
subikid90 Posted August 6, 2010 Share Posted August 6, 2010 97 has a different bulb. Dont pull on it, it wont pull out. You have to remove the rubber cover and undo the metal thing that holds the bulb in -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
LiCelsior Posted August 6, 2010 Share Posted August 6, 2010 97 has a H4 bulb no? if so its a 3prong, and hes trying to remove the connector not the bulb. i swapped to jdm projector headlights so i forgot what my 97 bulbs were. edit: just checked and yea the connector is in there pretty snug. removing the rubber shroud and then pulling on the electrical base will get it off. Link to comment Share on other sites More sharing options...
daleyswanson Posted August 6, 2010 Share Posted August 6, 2010 pinch (fairly hard) and pull. wiggling doesn't hurt either. i just did this today. we are talking about removing the plug that goes into the back of the headlight correct? Link to comment Share on other sites More sharing options...
