tdoggydog Posted February 3, 2010 Share Posted February 3, 2010 For those of us with stock nav, you know that you can access setting for the car such as to chirp or not when the alarm is activated/deactivated, etc. My question is, if the stock nav unit is replaced, are these setting no longer accessible? How do those of you without nav adjust these settings? Thanks! Link to comment Share on other sites More sharing options...
AkumaMax Posted February 3, 2010 Share Posted February 3, 2010 look on the back of the key fob it will tell you how to turn it on/off Link to comment Share on other sites More sharing options...
tdoggydog Posted February 3, 2010 Author Share Posted February 3, 2010 look on the back of the key fob it will tell you how to turn it on/off Huh? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 3, 2010 Share Posted February 3, 2010 For those of us with stock nav, you know that you can access setting for the car such as to chirp or not when the alarm is activated/deactivated, etc. My question is, if the stock nav unit is replaced, are these setting no longer accessible? How do those of you without nav adjust these settings? Thanks! They either have to have the dealer do it via the SSM or through a sequence of things like turning the key to the on position, opening the door, holding a button for ten seconds, etc. I don't think I've changed any of those settings once they were set though. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 3, 2010 Author Share Posted February 3, 2010 They either have to have the dealer do it via the SSM or through a sequence of things like turning the key to the on position, opening the door, holding a button for ten seconds, etc. I don't think I've changed any of those settings once they were set though. Ah, gotcha. Thanks! I would imagine the settings are retained if the battery is disconnected, right? Link to comment Share on other sites More sharing options...
