Research Turbo Build
it will handle it but it wont be reliable for long id suggest updating to stronger trans and diffs
a jdm 6speed would be hawt
Would a 5-Speed AWD Manual 4X4 EJ20 Turbo Subaru WRX Impreza GC8 tranny mount up to a EJ25
there is no difference in gear size/strength between any 90-02 5-speed. in around 03/04 they started putting in slightly wider gears commonly known as the 05+ LGT gearset. Note I said slightly.
You do need a turbo front crossmember and swaybar to clear the exhaust manifold and up-pipe.
The biggest challenge of doing something like this IS NOT getting the parts to physically fit. Pretty much everything is a bolt in deal.
The hard part is actually wiring the car so it actually works.
Well im gonna use a 2.5GT as a platform for the 2.5T motor so the wiring shouldnt be so bad. it wont be as bad as the wrx neon we just finished up
