EMZ23 Posted July 21, 2011 Share Posted July 21, 2011 I own a '94 GT Legacy Twin Turbo (Boxer) Wagon. Bought it second hand but with a known clutch problem. Decided to change many of the parts but am having problems identifying part specifications, Part numbers to be exact, for the following parts Clutch plates & Disc Rear Struts (Bellows too?) I nid a shift stick too with a built in (Boost?) button. Where can i get these? There's a crickety crank grind in the front wheel bearing when turning. What part needs replacement? Am residing in East Africa.. knowledge on where i can get these parts and shipping info would be quite helpful. Now, for my major problem ... I usually warm the engine for about 10 minutes every morning before i head out. During this period however, while idling (obviously) the RPMs intermittently rise from 1500 to about 2500 and then back to the idling about 1200 ... at will without pressing on anything... atleast every 20 - 45 seconds. This only stops when i drive off. What am i up against. At first i thought maybe this is how turbos behave but... shouldnt an engine nurturally simply tone down during warm up without the hic ups?? Then also, there is a prolonged ignition delay while starting the car when the engine isnt hot. I just wish i had a repair manual for this car. Any one with a soft copy?? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted July 21, 2011 Share Posted July 21, 2011 idk how to help you.. here http://www.rockauto.com? Link to comment Share on other sites More sharing options...
johnegg Posted July 21, 2011 Share Posted July 21, 2011 manuals http://www.main.experiencetherave.com/subaru_manual_scans/ part numbers maybe available at http://opposedforces.com/parts it will take some time to learn the process but once you get the hang of it you should be able to find most numbers. it is just a matter of looking in the right place. i don't know if they will shipp international, but i use some of these suppliers: http://subarupartsforyou.com/ https://www.subarugenuineparts.com/oe_parts_cat.html of course these are in the US. i would think europe or asis would be a better source for you. Link to comment Share on other sites More sharing options...
EMZ23 Posted July 22, 2011 Author Share Posted July 22, 2011 Thanks Johnegg, especially for manuals. Got the hang of it. Can clearly see what part i need plus part number. Now .. about my car behavioral issues ... any help?? Rockauto rocks... n' subarugenuineparts Link to comment Share on other sites More sharing options...
johnegg Posted July 22, 2011 Share Posted July 22, 2011 re: subarugenuineparts.com i just read today that since our friend ''subiegal'' does not work there any more the service for online parts orders has dropped off DRAMATICALLY . so a word to the wise.... hopefully they will sort it out and be back on track. EMZ23, send me an email , canubaru at gmail dot com . Link to comment Share on other sites More sharing options...
AndrewZ Posted August 9, 2011 Share Posted August 9, 2011 re: subarugenuineparts.com i just read today that since our friend ''subiegal'' does not work there any more the service for online parts orders has dropped off DRAMATICALLY . so a word to the wise.... hopefully they will sort it out and be back on track. EMZ23, send me an email , canubaru at gmail dot com . To second this, my last order took a couple weeks to ship. There was a problem with it and they haven't responded to any of my emails (it's been a week). They don't have their number on their website, either. Link to comment Share on other sites More sharing options...
babybaluga32 Posted August 9, 2011 Share Posted August 9, 2011 +1 on crappy service from subarugenuineparts.com! It was like 3 months ago. They took about 2 weeks to cancel my order and send my money back becasue they didnt have the part. ever. Link to comment Share on other sites More sharing options...
AndrewZ Posted August 10, 2011 Share Posted August 10, 2011 I found their number on NASIOC, it's (425) 641-2002. I was able to get everything sorted out it seems over the phone. The number is, I believe, for the dealership at large so mention that you're calling about an order through the website. Link to comment Share on other sites More sharing options...
woodlandapple Posted August 11, 2011 Share Posted August 11, 2011 maybe a silly question, I have the same car, JDM 94 GT TT, are those manuals linked to accurate for my car? I am having trouble sourcing a starter motor, knowing nothing about cars, I want to armmyself with as much knowledge as I can. Link to comment Share on other sites More sharing options...
louGT Posted August 12, 2011 Share Posted August 12, 2011 Chap, I'm in Nairobi, had the same RPM problems with my GC8. The issue could be the throttle body, as mine was. All it took was a thorough wash in premium petrol and that got sorted out. Funny thing is there were about 3 other subies at the garage with that same problem. You'll also need to check your MAF in case there's any trace of smoke from your exhaust at startup. 10 minutes is also a lot for warm up, 2 - 3 minutes should do it. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted August 14, 2011 Share Posted August 14, 2011 The crickety crank grinding sounds like you need to replace the wheel bearing to me. Link to comment Share on other sites More sharing options...
