10thgroupvet Posted June 6, 2009 Share Posted June 6, 2009 I have 08 OB XT. Installing my used (older) 2 pot Brembos on Rear (I have everything now--adapter shoes and brackets). Will the Goodridge SS lines for the +04 Legacy fit the from the OB hard-line to the Brembos? Will they bolt to the Brembos? Any other brands or recommendations on rear lines. I have the StopTechs working up front. Just need lines to properly finish rear (rubber lines on now). Thanks Link to comment Share on other sites More sharing options...
obxt Posted June 12, 2009 Share Posted June 12, 2009 What lines did you use on the front? I have an '05 OBXT with LGT Brakes on the front, and stock rears. I'd like to put SS lines on, but I can't find any information on which (if any) will fit. Link to comment Share on other sites More sharing options...
10thgroupvet Posted June 13, 2009 Author Share Posted June 13, 2009 I used StopTech lines in the front. They came with a set of used 4-pot StopTechs I put on the front. I've been told that the LGT lines (any brand) will fit. Haven't tried it yet, put I'm going to give it a whirl with some Techna-Fits for the rear. I don't believe that StopTech makes lines specifically for an OBXT, so they must have been for a LGT, and they fit fine, even with the wheels at full droop while on the jack. Link to comment Share on other sites More sharing options...
ScoobySTi07 Posted June 13, 2009 Share Posted June 13, 2009 The fronts should be fine as they are the same length and I believe part number as the LGT. The rears however, are slightly longer and a different part number. The couple of guys on here that I know who have installed SS lines made for the LGT on Outbacks with unmodified suspension report the rear's as being "tight". I gather the difference is maybe an inch or 2. To my knowledge the only company that makes OBXT specific SS lines is Techna-fit. As for the Brembo connection the 04 Legacy is an entirely different car so I would kind of doubt it. Use the Techna-fit lines and save yourself the headache. The Ridiculousness is no more But you can have your very own piece of it. **The Ridiculous Part Out.** Link to comment Share on other sites More sharing options...
