SpideR Posted April 28, 2012 Share Posted April 28, 2012 I'm afraid I know the answer to this question, but I'll ask anyway. I gotta replace my oil pan. Am I gonna have to remove the crossmember to do that? Link to comment Share on other sites More sharing options...
mwm5094 Posted April 28, 2012 Share Posted April 28, 2012 Motor mounts my friend Link to comment Share on other sites More sharing options...
SpideR Posted April 28, 2012 Author Share Posted April 28, 2012 And then lift the motor up a few inches? Is there enough interior clearance for it to drop out that way? Link to comment Share on other sites More sharing options...
nospmoht04 Posted April 28, 2012 Share Posted April 28, 2012 Yeah there's enough. I used a jack under the motor while it was up on a lift. Lower the lift a few inches and stick blocks by the mounts. Pan came off no problems at all. Link to comment Share on other sites More sharing options...
mwm5094 Posted April 28, 2012 Share Posted April 28, 2012 ^ +1 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 28, 2012 Share Posted April 28, 2012 Why are you removing your oil pan? checking oil pickup tube or some other reason? just curious.. Link to comment Share on other sites More sharing options...
SpideR Posted April 29, 2012 Author Share Posted April 29, 2012 Why are you removing your oil pan? checking oil pickup tube or some other reason? just curious.. The bottom of it got smashed in on an "excursion" over a tall curb Link to comment Share on other sites More sharing options...
PutnamCO Posted April 29, 2012 Share Posted April 29, 2012 The rear bolts are a bit of a pain, but you can get them all by following the above advice. PM me your e-mail address if you want the step-by-step instructions Killer B sent me when I pulled mine. Link to comment Share on other sites More sharing options...
suds2250 Posted April 29, 2012 Share Posted April 29, 2012 And don't forget to remove the pitch stop if you are going to raise the engine. It's below the intercooler. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
slowGT Posted April 29, 2012 Share Posted April 29, 2012 If you go easy it is not necessary to remove the pitch stop. I didn't remove it and had no problems. I guess it wouldn't hurt to remove it but that's just one more thing to have to do. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 29, 2012 Share Posted April 29, 2012 Make sure you have a good 6 point 14mm socket for the motor mount bolts. Yesterday I had to use a 1/2 impact gun to remove the two nuts. The 1/2 ratchet was not doing very well on breaking them loose even after the PB Blaster sat on them for a while. The impact had no issue removing the nut's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 29, 2012 Share Posted April 29, 2012 The bottom of it got smashed in on an "excursion" over a tall curb If you yank your pan from an impact and do not have a replacement reinforced oil pickup in hand to install when you do it you may kick yourself. I believe my oil pan impact (empty compressed gas tank ejected from a moving vehicle next to me, hit another car and spun across the highway under my car at the most bizzare angle imagineable) was the hit that caused my harmonically stressed pickup to crack. It did not break but it was only a matter of time. Never regretted replacing it when I replaced the pan. Pan has been off the LGT two times and the OBXT once. LGT = killerB pan/tray/pickup OBXT = KillerB pickup Link to comment Share on other sites More sharing options...
Max Capacity Posted April 29, 2012 Share Posted April 29, 2012 Here's a good question. How to you remove the oil pan from the dip stick tube ? I have my engine on the engine stand, the oil pan is loose, no more bolts in it but I still can't get the tube out of the pan. I have not removed the cam gears so I can't slide the tube down behind them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 29, 2012 Share Posted April 29, 2012 if you yank your pan from an impact and do not have a replacement reinforced oil pickup in hand to install when you do it you may kick yourself. ^+1. Link to comment Share on other sites More sharing options...
vtbimmer Posted April 29, 2012 Share Posted April 29, 2012 Here's a good question. How to you remove the oil pan from the dip stick tube ? I have my engine on the engine stand, the oil pan is loose, no more bolts in it but I still can't get the tube out of the pan. I have not removed the cam gears so I can't slide the tube down behind them. I removed and installed the dipstick tube with the engine still in while I was replacing the pan and pickup. I just used a cloth wrapped around the tube with visegrips lightly attached. Hammered up on the vise grips to detach tube from pan and then wiggle it up and out. Getting the tube back down to the pan was a bit harder but do-able and I used a little grease on the O-ring to help it slide in. Edit--- Of course there is one bolt holding the dipstick tube in place. I was assuming this bolt is removed. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 29, 2012 Share Posted April 29, 2012 I removed the oil pick up tube, which is fine, I will reuse it, remember mine is a early 05, bought it late Jun 04. Once I could spin the pan around and after some tugging like a mofo, that sucker popped off. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SpideR Posted April 30, 2012 Author Share Posted April 30, 2012 Thanks for all the replies and advice everyone! I do indeed have another pickup coming, as I figured it might have gotten damaged. With all the other work needed because of this whole thing, I'm still debating whether to take it in to the shop for the oil pan bit. Both left wheels are bent, the left front LCA w/ ball joint and all hardware, the LF hub / bearing, LF knuckle, and the crossmember support bracket, in addition to the pan and pickup. Obviously the under cover is pretty well beat after this was well. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 30, 2012 Share Posted April 30, 2012 Sounds like an insurance claim...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 30, 2012 Share Posted April 30, 2012 This is not an oil pan hit. This is a major accident. This is what insurance is for. Link to comment Share on other sites More sharing options...
Berzerklo Posted April 30, 2012 Share Posted April 30, 2012 It did not break but it was only a matter of time. Never regretted replacing it when I replaced the pan. Pan has been off the LGT two times and the OBXT once. LGT = killerB pan/tray/pickup OBXT = KillerB pickup Don't mean to threadjack, but is the killerB pan taller than stock? I am definitely thinking about the pickup and tray but I only want to do the pan if I don't lose ground clearance. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 30, 2012 Share Posted April 30, 2012 Its about the same its just much BLOCKIER instead of curved. I spend a lot of time near 1g in turns so the baffle and extra oil supply was a no brainer. The pan is expensive, if you don't need it... Link to comment Share on other sites More sharing options...
SpideR Posted April 30, 2012 Author Share Posted April 30, 2012 This is not an oil pan hit. This is a major accident. This is what insurance is for. Yes, yes it is. When I started the thread, I didn't know the knuckle and hub were bad, and the crossmember support looked like it had just been scuffed. I took the car over to the local Subaru dealer, and the tech let me under the car on the lift and that's when I saw the additional damage. Really the crossmember support isn't that bad at all and could likely just stay on the car, but considering how inexpensive it is it may as well just get replaced to do the job "right". I had already known about the wheels and the control arm, and was just going to fix those myself, since it really wasn't much more than the deductible. Obviously after my additional discoveries and the other stuff the dealer found made this a whole different ball game. I do have an adjuster coming out to look at the car, and I'm going to get a detailed estimate from the dealer to show him so that I don't get lowballed too badly. I still plan on doing a good portion of the work myself because I want to, but I'm not sure I will be doing the oil pan on top of all the other work; we'll see. The cool thing is the insurance will just cut me a check directly, and let me deal with lining up the repairs, so I will have the flexibility to do it the way I want. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 30, 2012 Share Posted April 30, 2012 I'm just sorry that you had to take a hit to your carfax and insurance. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 30, 2012 Share Posted April 30, 2012 I'm just sorry that you had to take a hit to your carfax and insurance. ^yeah that's true. At least though, you'll be able to explain what you fixed if you ever sell your car since you are getting involved in the repairs. Good on ya. Link to comment Share on other sites More sharing options...
SpideR Posted April 30, 2012 Author Share Posted April 30, 2012 I'm just sorry that you had to take a hit to your carfax and insurance. Carfax, yeah that's kinda uncool but what can ya do? Maybe I'll get lucky and will be classified as minor, or maybe not get reported at all . Regardless I'll have the receipts to show what was actually done, so that should help. I haven't had a claim on insurance in over five years, so I doubt it'll change much (if at all). At least that's what I'm hoping! Link to comment Share on other sites More sharing options...
