Gemini91 Posted July 3, 2010 Share Posted July 3, 2010 How do you guys change the air filter? I took off the whole intake to replace the air filter and it took a lot of time... Any easier way? Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 3, 2010 Share Posted July 3, 2010 panel filter or CAI? either way is really quite simple.. Link to comment Share on other sites More sharing options...
Gemini91 Posted July 3, 2010 Author Share Posted July 3, 2010 CAI, I can easily disconnet the air filter from the intake easily but can't get it out becuase it's stuck by the heat shield... Link to comment Share on other sites More sharing options...
Balrock Posted July 3, 2010 Share Posted July 3, 2010 You only have to clean it like once a year? It's just a couple bolts to loosen the silcone hoses and pull the whole thing out. Washing the filter and waiting for it to dry, that takes alot longer so an extra 5 minutes isn't gonna kill. Link to comment Share on other sites More sharing options...
Gemini91 Posted July 3, 2010 Author Share Posted July 3, 2010 wait a minute...this filter is washable? Link to comment Share on other sites More sharing options...
JaeGT Posted July 3, 2010 Share Posted July 3, 2010 wait a minute...this filter is washable? yep. http://www.fredbeansparts.com/index.php/induction/kandn-filter-recharger-kit.html just wash with soap, rinse, air dry and re-oil with the stuff above. then you're good to go Link to comment Share on other sites More sharing options...
Balrock Posted July 4, 2010 Share Posted July 4, 2010 Do not wash with soap. Go to autozone or whatever and K&N sells a kit that comes with a cleaner and the aersol oil in a can. I mean soap may not be bad, but I just go with whatever the manufactuer sells. I have cleaned and oiled the filter at least 3 times on the same kit. If your K&N filter is not oiled you are sucking in nasty shit!! The oil catches all the garbage from getting in the intake. Link to comment Share on other sites More sharing options...
