jimmystikx Posted May 29, 2016 Share Posted May 29, 2016 What is the original back spacing for the 14in steelies and what is needed to run set of 16x7/7.5s with out rubbing and overly affecting my scrub angles. I plan on upgrading the brakes for Lemons races down the line at some point. Link to comment Share on other sites More sharing options...
jimmystikx Posted May 30, 2016 Author Share Posted May 30, 2016 Nothing? Link to comment Share on other sites More sharing options...
Brighton96 Posted May 30, 2016 Share Posted May 30, 2016 I run 16x16.5 with +35 spacing without any problem. As far as I've seen most of Subaru stock wheels are 30-40+ offset. Link to comment Share on other sites More sharing options...
jimmystikx Posted May 30, 2016 Author Share Posted May 30, 2016 Is that a stock backspacing or are you running aftermarkets? Link to comment Share on other sites More sharing options...
Brighton96 Posted May 30, 2016 Share Posted May 30, 2016 That's stock back spacing and I am running stock wheels. I have had several OEM wheels on my car and they've all fit. I have had 17x7 +30 GTB wheels, 3rd Gen H6 16x6.5 +35 wheels and 4th gen 17x6.5 +35 GT wheels. These are with Legacy AND Outback struts, the only problem I ran into was larger tires (225/70) rub on the struts when mounted on the 16x6.5 with Legacy Struts. Link to comment Share on other sites More sharing options...
jimmystikx Posted May 31, 2016 Author Share Posted May 31, 2016 I was planning on keeping the overall diameter relatively close to stock, I just want to improve the brakes down the road once money comes available for it, and I can determine if I'll actually make this a Lemons series car. Thanks for the info. Link to comment Share on other sites More sharing options...
Brighton96 Posted May 31, 2016 Share Posted May 31, 2016 You can clear wrx 2 piston fronts on 11in rotors and H6 2 piston rears with 10.5in rotors with lots of space of spare with 16x6.5 +35. That's the set up I have and I would say I have about an inch of space all the way around the calipers to the rims. Link to comment Share on other sites More sharing options...
twisty Posted May 31, 2016 Share Posted May 31, 2016 i had 17x7.5 +43 wheels with 205/45 tires on stock suspension with no rubbing. this is within .25" of the oem diameter as well. Link to comment Share on other sites More sharing options...
Cale Posted June 2, 2016 Share Posted June 2, 2016 That's stock back spacing and I am running stock wheels. I have had several OEM wheels on my car and they've all fit. I have had 17x7 +30 GTB wheels, 3rd Gen H6 16x6.5 +35 wheels and 4th gen 17x6.5 +35 GT wheels. These are with Legacy AND Outback struts, the only problem I ran into was larger tires (225/70) rub on the struts when mounted on the 16x6.5 with Legacy Struts. Are you sure about those offsets? All OEM Subaru wheels (USDM/JDM) I know of have offsets between +48-55mm Link to comment Share on other sites More sharing options...
Brighton96 Posted June 2, 2016 Share Posted June 2, 2016 Are you sure about those offsets? All OEM Subaru wheels (USDM/JDM) I know of have offsets between +48-55mm Good call on checking that, I guess I've forgotten backspacing specs with time. The GTBs were +53 and the 4th Gen are +55. My other two wheels aren't listed on this thread but it's a great source of info. http://forums.nasioc.com/forums/showthread.php?t=2239019 Link to comment Share on other sites More sharing options...
jimmystikx Posted June 10, 2016 Author Share Posted June 10, 2016 Thanks for all the info guys. Link to comment Share on other sites More sharing options...
