psucaptainkickass Posted August 21, 2005 Share Posted August 21, 2005 Update: The short story is, the plastic bezel around the shifter is not flush with the plastic piece that houses the climate controls. Specificially it is the right side that does not fit right. In general, the bezel does not have a tight fit in its position and has play in it. Read on for more info. For updates start at the end of page 2. Link to comment Share on other sites More sharing options...
red beast Posted August 21, 2005 Share Posted August 21, 2005 let them do it. this way if they scratch it, they replace it. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 21, 2005 Share Posted August 21, 2005 Just push on it- mine wound up that way when I had my console apart. Link to comment Share on other sites More sharing options...
edmundu Posted August 21, 2005 Share Posted August 21, 2005 Mine has been like that since day 1! I've tried to even it out, but it hasn't worked for me. Link to comment Share on other sites More sharing options...
RSM Posted August 21, 2005 Share Posted August 21, 2005 Yup...mine has looked like that from day one also.. Link to comment Share on other sites More sharing options...
gt_ltd Posted August 21, 2005 Share Posted August 21, 2005 subaru sucks This Space For Rent Link to comment Share on other sites More sharing options...
Lagacy GT Posted August 21, 2005 Share Posted August 21, 2005 what's wrong with the picture? Link to comment Share on other sites More sharing options...
godwhomismike Posted August 21, 2005 Share Posted August 21, 2005 What's a firx? Link to comment Share on other sites More sharing options...
Edvig Posted August 21, 2005 Share Posted August 21, 2005 My car was like that from, day one as well. You have a broken clip. Do you have a subwoofer? It's possible that the dealer broke the clip when then ran the subwoofer connection or installed the STS. Link to comment Share on other sites More sharing options...
mccorry Posted August 21, 2005 Share Posted August 21, 2005 Mine has been like that since Day 1 also....tried to adjust it, but no go.... Link to comment Share on other sites More sharing options...
alpinefun Posted August 21, 2005 Share Posted August 21, 2005 Same picture since day one. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 21, 2005 Share Posted August 21, 2005 For those of you who haven't done so already, here's a resource on how to completely disassemble the console trim area - http://legacygt.com/forums/showthread.php?t=1626 The plate/section that y'all will be working with actually will come out of its current area without your having to remove the side trim pieces. Steps 1 and 2 are what you're interested in, for the above. Next, simply follow "step two" in this following walk-through: http://legacygt.com/forums/showthread.php?t=16708 - to completely remove that particular trim panel. You do *NOT* need to remove your shift knob to do this. Now, just re-seat the panel you've popped loose. Make sure you re-seat the two tabs that mate to the head-unit panel, first. Hope this helps. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
psucaptainkickass Posted August 21, 2005 Author Share Posted August 21, 2005 Yeah i think I will just take it to the dealer. If it's supposed to be flush, its supposed to be flush, plain and simple. Link to comment Share on other sites More sharing options...
mccorry Posted August 22, 2005 Share Posted August 22, 2005 I already tried to remove and reinstall the piece 3 times... it always goes back to the position pictured above. I really think one of the pieces is made wrong.... Link to comment Share on other sites More sharing options...
mmm def Posted August 22, 2005 Share Posted August 22, 2005 Mine is the same way. O well. Link to comment Share on other sites More sharing options...
themute Posted August 22, 2005 Share Posted August 22, 2005 My car was like that from, day one as well. You have a broken clip. Do you have a subwoofer? It's possible that the dealer broke the clip when then ran the subwoofer connection or installed the STS. there is your answer Link to comment Share on other sites More sharing options...
mccorry Posted August 22, 2005 Share Posted August 22, 2005 My car was like that from, day one as well. You have a broken clip. Do you have a subwoofer? It's possible that the dealer broke the clip when then ran the subwoofer connection or installed the STS. Lets take a poll.... yes.. mine is broken and I do have a factory subwoofer installed. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted August 22, 2005 Author Share Posted August 22, 2005 Mine is broken (obviously), and I have the STS Link to comment Share on other sites More sharing options...
TSiWRX Posted August 22, 2005 Share Posted August 22, 2005 ^^^ mccorry - Ayup, looks like something is broken for you guys. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Legacy05 Posted August 22, 2005 Share Posted August 22, 2005 mine is that way too, but I just pulled up on the trim on the right side by the shifter and it lined up ... Link to comment Share on other sites More sharing options...
GBY Posted August 22, 2005 Share Posted August 22, 2005 Thread moved to Warranty Issues & Problems. Dave. Link to comment Share on other sites More sharing options...
03Indigo Posted August 26, 2005 Share Posted August 26, 2005 mine is fine, and I have the factory (not dealer) installed sub woofer, no STS. Had the car since Feb '05 Link to comment Share on other sites More sharing options...
mccorry Posted August 26, 2005 Share Posted August 26, 2005 OK.. I have messed with mine a few times now. If I pull up on the plate, it will pop into place. However, it will not line up with the silver side trim as well. Plus, if you put any weight on it... it clicks back down into the other position (shown in original post). I inspected all of the parts and cannot find anyplace where there are missing clips or signs of cracked off pieces. They all look fine. I would realy like to meet up with someone who doesn't have the gap so I could compare the parts and see what the issue is. Volunteers? Link to comment Share on other sites More sharing options...
psucaptainkickass Posted September 12, 2005 Author Share Posted September 12, 2005 Long overdue update, went to the dealer today, said that it somehow got warped and they will special order the part in to fix it. Link to comment Share on other sites More sharing options...
icehousewvu Posted September 12, 2005 Share Posted September 12, 2005 +1 Since the day I brought it home Link to comment Share on other sites More sharing options...
