JVranicar Posted June 18, 2013 Share Posted June 18, 2013 My everyday car is a stock 06LGT MT with 72k miles. I'm the second owner and purchased the car with 6k miles on it. My LGT leads a modest life with a 25 mile round-trip weekday commute from the suburbs to downtown KC. Half residential/half Interstate miles. Plus, I take 400 mile round trip drives to Nebraska ~5x per year. I change the oil every 3.5k miles and check the oil levels at least 1x per month. I have also been diligent RE regular maintenance according to the prescribed schedule. Frankly, I rarely push this car. In fact, I baby it. All these posts about these cars needing replacement turbos and/or worse yet, replacement engines has me seriously wondering how much longer I should keep this car. Pre, my reading of this board, I planned on keeping the car for at least four more years up to an estimated 125k miles. I still may do that. It is a blast to drive and still looks great. Are the turbo/replacement horror stories I read on this board more the exception or the rule? Based on my above described use of this vehicle, how concerned should I be that a blown turbo is in my future? Anyone have an idea of what percentage of 4Gen LGTs have this issue? Any words of wisdom from the LGT masses would be greatly appreciated. Thanks! Link to comment Share on other sites More sharing options...
Moddiction Posted June 18, 2013 Share Posted June 18, 2013 Just check the turbo if you're worried. If it needs to be replace it and continue on. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
chato Posted June 18, 2013 Share Posted June 18, 2013 there are two things that are completely normal outcomes from owning a LGT and reading this site. Paranoia about engine sounds (ringland failure, rod knock, turbo whine) and lust for endless expensive aftermarket parts. If you can't hang with either, or both of those, you might want to tap out. Link to comment Share on other sites More sharing options...
Gex Posted June 18, 2013 Share Posted June 18, 2013 Poorly tuned and maintained cars blow up. Keep calm and carry on. Link to comment Share on other sites More sharing options...
chato Posted June 18, 2013 Share Posted June 18, 2013 joking aside, there are four things you can do. 1. pull the downpipe and check the shaft in the turbo for play. 2. check the screens in the banjo bolts, if they are clogged you may have an issue. 3. get a compression/leakdown test. if these all go well, 4. get your car off the stock map. Link to comment Share on other sites More sharing options...
JVranicar Posted June 18, 2013 Author Share Posted June 18, 2013 Very helpful chato. Much appreciated. Link to comment Share on other sites More sharing options...
jp233 Posted June 18, 2013 Share Posted June 18, 2013 I was going to write basically the same thing that chato did. It is always easier, and less mental/heartache, to inspect for problems and feel good about things, rather than to get blindsided and get all bent outta shape. If you do a compression test, you may as well change the spark plugs then too. The FSM has lots of simple inspections that you can do. Especially, w.r.t. electronic gadgetry (like for instance, checking the injectors, plug wires, sensors, etc). Link to comment Share on other sites More sharing options...
chato Posted June 18, 2013 Share Posted June 18, 2013 couple more thoughts which are more on the basic side, if the above tests are good, just run good oil and filters, religious about check your oil level. Another consideration are the known smaller common maintenance items that can really add up, especially if you are not doing work yourself like: valve cover gaskets, power steering pump and rack, front LCA bushings, starter, clutch, wheel bearings, axle boots and seals... Link to comment Share on other sites More sharing options...
Max Capacity Posted June 18, 2013 Share Posted June 18, 2013 Hey you've about covered all the issues there. Good Reading. At 141,000 miles my wagon gave me the heads up the turbo is going. CEL P0011 and P0022, mechanic pulled the banjo filter, it didn't look bad. I still have it here at my desk. After that the trubo whined for the next 100o miles, during that time I did my homewrok and picked out a vf52 when needed. The morning the whine changed to a whistle I stopped and replaced the turbo. Went to the dyno and got a good tune. Drove the car another 12,000 miles and replaced the short block because of oil useage that was from abruse early on my me. The vf52 now has over 34,000 miles on it and is still quiet. Oh the first 154,000 miles on the car were on cheap 5w-30 from Walmart and Fram oil filters. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 18, 2013 Share Posted June 18, 2013 there are two things that are completely normal outcomes from owning a LGT and reading this site. Paranoia about engine sounds (ringland failure, rod knock, turbo whine) and lust for endless expensive aftermarket parts. If you can't hang with either, or both of those, you might want to tap out. No paranoia here:rolleyes:. But still waiting to wear out parts to replace them with "expensive aftermarket" ones. Who would've thought I wear out my struts before my turbo:eek: Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
rob-2 Posted June 18, 2013 Share Posted June 18, 2013 I was the second owner on this car. Bought with 59K, drove by ex-wife till about 90k. Went stage one shorlty after and 2k on stage 2. All regular service done by the local dealer. The motor is being rebuilt and I'll find out all the details on the low compression later. Typically you see people posting up problems on cars, but rarely so commonly problems that lead to very costly motor problems. Furthermore if you do your research you'll find Subaru has a known problem with their Turbo'd cars. LGT, WRX and STI - all suffer similar problems. I'll get the replies to this "The online posting is blown out of proportion to the actual failures" which in itself is laughable. Subaru America goes out of their way to prove abuse on their performance cars and claim that you damaged the car. It's well known that ringlands can fail and cars be driven for some time like this. I'd go as far as to suggest most drivers wouldn't know the feeling of a flat tire if they didn't have the caution light now to tell them. Based on my experience, and my research, this isn't a reliable enough car to keep. Some folks will report high mileage, but for every one of them there is the 'blew my motor' thread. As for paranio, that's a bit much, just keep $6k aside to rebuild your motor. No problems there right? Sell your car and buy something reliable. Any N/A subi will last longer if you're a fan boy, or a Toyota or Honda will do. FYI - I rebuilt mine because it was the most cost effective and I'm not willing to dump a problem on someone. Link to comment Share on other sites More sharing options...
Gire Posted June 18, 2013 Share Posted June 18, 2013 joking aside, there are four things you can do. 1. pull the downpipe and check the shaft in the turbo for play. 2. check the screens in the banjo bolts, if they are clogged you may have an issue. 3. get a compression/leakdown test. if these all go well, 4. get your car off the stock map. This. My car just rolled over 140k KMs (stock turbo / intercooler, stage 2) and I took it to my tuner shop friends for an inspection. they pulled the DP and inspected the turbo, checked all connections, checked the intercooler, etc. they said it was all in great shape. However my LCA bushings are worn out and I need new rear brake pads, and likely change the spark plugs and coolant, and fix the A/C in the very near future. But that's all maintenance on wear and tear items. With regular oil changes and other maintenance / inspections you are doing all you can to keep the car. the percentage of LGT owners who have blown up their car is small. Link to comment Share on other sites More sharing options...
rkhousman Posted June 18, 2013 Share Posted June 18, 2013 Yeah a well taken care of car will last. I bought mine 1.5 yrs ago with 125 k mi and only minor things have had to replaced such as struts, pass cv, seized front left caliper. Preventive I replaced the up with a non catted and have a BNR 16g sitting on the shelf waiting for install and tune. Car was well taken care of by previous owner and I am religious with the oil changes! Now have 153 k mi on the odo! Link to comment Share on other sites More sharing options...
Heticor Posted June 19, 2013 Share Posted June 19, 2013 Most of the people if not all that report turbo failures and engine problems are people that has the car modified to stage1, 2 or 3. Additionally they do their own maintenance, seldom visits to the dealer. If the rate of failures for a stock car were even similar to the posted here in the forum any company will be out the business in not time. I had a WRX before the Legacy and drove her for 300.000 km before I totaled. Not a single issue with the turbo neither the engine. That is why I got this one. The reliability of these cars in stock form is excellent. Now when the car is modified to get more that the car was design for, well these are the consequences. The more power you get the more risk that the components fail. Even if you built the engine to big HP , they will fail sooner or later. It depends what you want to do with the car. If you want enjoy the car with a little sport drive without any modifications, I would recommended to keep it, however if you want go the limit and do stage 1 or …444 well be ready with your wallet because this hobby is very expensive, I already did that. I enjoyed a lot however the cost were getting too high, now I am in other stage of live where I not want to break any speed records. Link to comment Share on other sites More sharing options...
JVranicar Posted June 20, 2013 Author Share Posted June 20, 2013 I'm a newbie here so bear with me. Can someone explain what stage 1, 2 and 3 modifications are? Also, can someone shed light on VF52 and VF40 refers to? Are those aftermarket turbos? Link to comment Share on other sites More sharing options...
lee07 Posted June 20, 2013 Share Posted June 20, 2013 You should really get on it once in a while, so you won't get carbon buildup on your intake valves(misfire) Just get a stage 1 custom tune and it will be fine My turbo and up pipe were in great condition when I took them off for the first time at 101k. I'm sure they would of lasted 300k+ if I wanted Vf52 is just a mild, small, direct fit turbo upgrade(+/-30hp) Link to comment Share on other sites More sharing options...
rob-2 Posted June 20, 2013 Share Posted June 20, 2013 I'm a newbie here so bear with me. Can someone explain what stage 1, 2 and 3 modifications are? Also, can someone shed light on VF52 and VF40 refers to? Are those aftermarket turbos? Cobb defined boost targets. Best search. Stage 1-2 can be done on stock turbo, once you change turbo you're stage 3. Link to comment Share on other sites More sharing options...
jp233 Posted June 20, 2013 Share Posted June 20, 2013 Stage definitions are in the stickies... Turbo definitions and lots of turbo talk is in the stickies... Link to comment Share on other sites More sharing options...
chato Posted June 20, 2013 Share Posted June 20, 2013 best way to search is to enter search operator terms in google. in the google search window enter site:legacygt.com followed by your keywords. This will be a google search limited to the lgt site. VF40 is the stock LGT turbo. VF52 is the stock Impreza STI turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 20, 2013 Share Posted June 20, 2013 As far as stock cars go, I don't know how many Subaru heads are from mod'ed cars, but my buddies machine shop has been doing at least one head rebuild a week for years now. When I stopped in last Thursday, he told me he just got a phone call from the service manager at Subaru. He joking said, "what's going on, you haven't sent me a head this week". The reply was, "You'll have one tomorrow". 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bluesuby Posted June 20, 2013 Share Posted June 20, 2013 Just one more comment on maintenance. Use synthetic oil and keep the change schedule right where it is. Link to comment Share on other sites More sharing options...
