samson303 Posted November 26, 2013 Share Posted November 26, 2013 I'm looking at buying a 2005 Legacy GT Limited, its an automatic transmission with 79,000 miles and listed at $11,900. Car is extremely clean inside and out and appears to having been well cared for over the years. The CarFax is clean, but there are a couple service records that stood out. 1. The turbocharger was serviced at 62,000 and checked again at 74,000. 2. The car failed emissions at 72,000 before having the emissions controls serviced and the drive axel serviced and passed emissions at 73,000 Any advice on pricing, issues and/or common problems with the car would be greatly appreciated. I'm having a mechanic look at the car later this week and would like to be able to suggest things for him to look out for. Thanks in advance. Link to comment Share on other sites More sharing options...
samson303 Posted November 26, 2013 Author Share Posted November 26, 2013 Here is the link to the original listing. http://www.texashotrides.com/2005-Subaru-Legacy-GT-Ltd-Addison-Texas-75001/4753091 And the link to the vehicle CarFax. http://www.carfax.com/VehicleHistory/p/Report.cfx?partner=AVR_0&vin=4S3BL676254207986 Link to comment Share on other sites More sharing options...
SBT Posted November 26, 2013 Share Posted November 26, 2013 The 5 previous owners, just by itself, would put me off. That's a combining effect that I wouldn't want to be concerned about. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted November 26, 2013 Share Posted November 26, 2013 ^Exactly. Link to comment Share on other sites More sharing options...
samson303 Posted November 27, 2013 Author Share Posted November 27, 2013 The 5 previous owners, just by itself, would put me off. That's a combining effect that I wouldn't want to be concerned about. The 5 owners is a little misleading. Dug a deeper and found out the following. Owner 1 - Corporate Car Owner 2 - Personal (Title transferred to employee's name from owner 1) Owner 3 - Personal Owner 4 - Dealer (Acquired as Trade In) Owner 5 - Dealer (Bought at auction from Dealer #4) Link to comment Share on other sites More sharing options...
stroker ace Posted December 5, 2013 Share Posted December 5, 2013 Compression test, Factory Momo steering wheel not option. Finally not STI wheels they a 5x114 Legacy should be 5x100. IMHO Link to comment Share on other sites More sharing options...
samson303 Posted December 5, 2013 Author Share Posted December 5, 2013 Compression test, Factory Momo steering wheel not option. Finally not STI wheels they a 5x114 Legacy should be 5x100. IMHO Getting a compression test done and I'll have results tomorrow. From what I've read I should be looking for 140-170 with less than 10% difference between cylinders. Anything else I should keep an eye out for? Pardon my complete ignorance with aftermarket parts, but please explain the issue with the MOMO steering wheel and STI wheels. I understand the 04 STI wheel is 5x100 and should theoretically work, while newer models are 5x114. So could this simply be the 04 STI wheel or are these actual the newer/wider model, and if so what problems would that create? Thank you!! Link to comment Share on other sites More sharing options...
discojon Posted December 5, 2013 Share Posted December 5, 2013 Getting a compression test done and I'll have results tomorrow. From what I've read I should be looking for 140-170 with less than 10% difference between cylinders. Anything else I should keep an eye out for? Pardon my complete ignorance with aftermarket parts, but please explain the issue with the MOMO steering wheel and STI wheels. I understand the 04 STI wheel is 5x100 and should theoretically work, while newer models are 5x114. So could this simply be the 04 STI wheel or are these actual the newer/wider model, and if so what problems would that create? Thank you!! See my thread from this week in this forum. Compression alone wont tell the whole story. I was looking at a clean 05 GT MT LTD that the compression was low but the leakdown showed the car needed a valvejob. Don't buy with out both tests being done. Link to comment Share on other sites More sharing options...
discojon Posted December 5, 2013 Share Posted December 5, 2013 And see my new thread as well. Two cars in a row failed compression tests with no obvious signs. Link to comment Share on other sites More sharing options...
stroker ace Posted December 5, 2013 Share Posted December 5, 2013 Getting a compression test done and I'll have results tomorrow. From what I've read I should be looking for 140-170 with less than 10% difference between cylinders. Anything else I should keep an eye out for? Pardon my complete ignorance with aftermarket parts, but please explain the issue with the MOMO steering wheel and STI wheels. I understand the 04 STI wheel is 5x100 and should theoretically work, while newer models are 5x114. So could this simply be the 04 STI wheel or are these actual the newer/wider model, and if so what problems would that create? Thank you!! There is no issue. It just seems "to me" that they are advertising that the factory Momo steering wheel and the older STI wheels are some "WOW" factor. Granted the wheels are a postive in the looks department if you like them or negative if you don't. I guess it was in my opinion that they don't make the price of the car any better or worse. Link to comment Share on other sites More sharing options...
samson303 Posted December 12, 2013 Author Share Posted December 12, 2013 Compression test results 151, 163, 148, 158 Just outside the range I was hoping for, but still pretty consistent. Any thoughts? Link to comment Share on other sites More sharing options...
SBT Posted December 13, 2013 Share Posted December 13, 2013 Oil into the cylinders during the test? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
firehawk618 Posted December 13, 2013 Share Posted December 13, 2013 It's not 5 owners as stated above BUT the one that would make me EXTREMELY nervous is the fact it was bought ~11/10 by someone with ~73,xxx miles. 3 years later it's only got 6k more miles on it? That tells me whoever bought it had nothing but trouble with it and dumped it. Just my opinion. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
