need bb Posted June 13, 2016 Share Posted June 13, 2016 While reviewing my logs I have noticed that they all have a dip in engine load in the mid range. I am not pulling timing and the boost is relatively stable. Any pointers would be greatly appreciated.3rd gear.csv Link to comment Share on other sites More sharing options...
solidxsnake Posted June 13, 2016 Share Posted June 13, 2016 Potentially load compensation tables playing into it? Disregard that, this is likely outside of the range of those tables having any effect. Link to comment Share on other sites More sharing options...
fahr_side Posted June 13, 2016 Share Posted June 13, 2016 Please plot both boost and load curves together so we can see how closely they correlate (or don't). Or just post your log. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
need bb Posted June 14, 2016 Author Share Posted June 14, 2016 Log should be posted in the original post. Link to comment Share on other sites More sharing options...
cBax Posted June 14, 2016 Share Posted June 14, 2016 My guess is boost leak. Your boost peaks and stabilizes before your load does. The turbo is working harder to maintain the target so load keeps climbing. Then as boost starts to drop, load comes back to where it should be. just a guess. But that's where I would start. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 14, 2016 Share Posted June 14, 2016 Time for a proper etune!! -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
need bb Posted June 15, 2016 Author Share Posted June 15, 2016 My guess is boost leak. Your boost peaks and stabilizes before your load does. The turbo is working harder to maintain the target so load keeps climbing. Then as boost starts to drop, load comes back to where it should be. just a guess. But that's where I would start. I spent a lot of time trying to find a boost leak after moving to my grimmspeed TMIC, but I could never find one. Using my boost leak tester I could hear some noise by the TMIC, but I could never find anything. Maybe the TMIC has a leak in the core? After changing the TMIC my spool is slower by about 200 RPMs and my WGDC increased which makes me think there is a leak. Brian I would be interested in optimizing my existing tune, but this issue seems mechanical related:mad: Link to comment Share on other sites More sharing options...
fahr_side Posted June 15, 2016 Share Posted June 15, 2016 You fit a bigger intercooler you will see some lag of course. But note that very often you will see a drop in MRP even MAF and load do not change, due to the cooler charge being more dense. If you are adding WGDC to keep MRP where it was on the TMIC you should be seeing more MAF and load as a result. If not, you're leaking or you've already maxed the turbo out. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 15, 2016 Share Posted June 15, 2016 I spent a lot of time trying to find a boost leak after moving to my grimmspeed TMIC, but I could never find one. Using my boost leak tester I could hear some noise by the TMIC, but I could never find anything. Maybe the TMIC has a leak in the core? After changing the TMIC my spool is slower by about 200 RPMs and my WGDC increased which makes me think there is a leak. Brian I would be interested in optimizing my existing tune, but this issue seems mechanical related:mad: I highly doubt the grimmspeed core is leaking. Mike our tuner is pretty good at identifying based off of logs where a leak is coming from. Get a smoker or bring it to someone who has one to identify the leak (if there is any). -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
