planelazy Posted October 2, 2011 Share Posted October 2, 2011 Quick ? about these... I got the CNT downpipe and SPT v2 exhaust, there is a slight leak.. even with 2 3" gaskets wedged between there... since my exhaust rubs up against my bumper, I'm going to put in some kartboy XL hangers to drop it a bit, but that will increase the gap between the cbe and dp.. IIRC The surface on the flange on the dp is smooth, I don't recall if the SPT has sa groove on it or not, but would jamming a donut gasket up there allow for a slight bend in the connection without leaking? Link to comment Share on other sites More sharing options...
m sprank Posted October 3, 2011 Share Posted October 3, 2011 Adapter and donut gasket or hang your cans with the XL hangers and have a muffler shop remove and replace the 2.5" restriction. Link to comment Share on other sites More sharing options...
bermo Posted October 3, 2011 Share Posted October 3, 2011 The easiest thing to do is the 3" to 2.5" adapter that msprank sells. If it starts to leak around the flat 3" gasket try a bead of RTV around the outside. Link to comment Share on other sites More sharing options...
planelazy Posted October 3, 2011 Author Share Posted October 3, 2011 The adapter looks pretty thick.. I don't think I would have enough room to put it. I'm wanting to put in a resonator.. I should have searched first too LOL I found out what restiction Mike was talking about (I had a hunch it was the ypipes).. that would fix my fitment issue. I'll just take it to a shop and get new y-pipes made and hack up the mid and throw in a magnaflow resonator. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 20, 2012 Share Posted May 20, 2012 So the spt cbe is 2.5 to mate up with the cnt DP? Link to comment Share on other sites More sharing options...
m sprank Posted May 20, 2012 Share Posted May 20, 2012 No. The CNT down pipe is 3". The SPT CBE is 2.5". If you want to mate them properly you need an adapter. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2012 Share Posted May 21, 2012 So i need the greemspeed adapter and a donut gasket and a greemspeed flat gasket? or what do i accualy need? If i need a flat gasket will the greemspeed one that i used work or do i need a new one? Link to comment Share on other sites More sharing options...
m sprank Posted May 21, 2012 Share Posted May 21, 2012 Grimmspeed or generic adapter. I am not a fan of re-using gaskets. But it is your call. None of the adapters come with gaskets. The GS comes with hardware. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2012 Share Posted May 21, 2012 So i need a grimmspeed adaptor, donut and flat gasket. Right? Link to comment Share on other sites More sharing options...
m sprank Posted May 21, 2012 Share Posted May 21, 2012 That would replace all the used gaskets with new, and should seal up the two pipes. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2012 Share Posted May 21, 2012 Okay thanks Link to comment Share on other sites More sharing options...
