Lookatmyrust Posted February 19, 2011 Share Posted February 19, 2011 i got a very loud sweak in my car that only heppens when on the gas. the only time it dont sweak while on the gas is when turning a little left. i recently just adjusted the tierod endlike like 1 degree at the most. now my car follows lines in the road. it always sweaked like this before i adjusted it it is just louder now. i checked on my levels. and they are fine now. Link to comment Share on other sites More sharing options...
Trbulnt Posted February 20, 2011 Share Posted February 20, 2011 What the heck is a sweak? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 you need to go get your car aligned. You can't just adjust your tie rods and hope for the best. If your car is wandering following grooves in the road and your tires are squeaking while driving, your toe is SEVERELY out and you need a professional alignment. Your car is NOT safe to drive like this. Go get it fixed properly -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 20, 2011 Author Share Posted February 20, 2011 mine is not out.. i put it more in. i just need a front wheel alignment? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 out as in not where its suppose to be. outside of specs. You need a 4 wheel alignment. Your front tires are aligned to the rear tires. So if the rears are not aligned correctly your fronts wont align correctly. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 20, 2011 Author Share Posted February 20, 2011 really the back are only camber Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 wrong. the rears have no factory camber adjustment. They have TOE adjustments only. You can install aftermarket camber bolts to allow for camber adjustments though. Your front toe is set according to your rear toe. Trust me I know what I'm talking about. I do this shit for a living lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 If your car is all stock, you have front camber and toe adjustments, and rear toe adjustments. nothing else -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 20, 2011 Author Share Posted February 20, 2011 ok. the 1st time i went in for an alignment they told me my wheel bearings were bad. can they not do an alignment when there is a little play? but i checked them all yesterday and were tight. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 They may and may not have play depending on how you jack up the car. On a Mcferson style strut setup (like your car), you have to check the front end for play with the suspension unloaded...meaning you DO NOT jack it up from the control arms. Most alignment techs jack every car up from the lower control arms. This is the wrong method on a Subaru. Another way to check the wheel bearings is to grab the strut spring and spin the wheel. If you have bad bearings, you will feel grinding through teh strut. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 20, 2011 Author Share Posted February 20, 2011 when i jack my car up i jack it up from the chassis.. like below the doors. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 20, 2011 I Donated Share Posted February 20, 2011 yeah thats how youre suppose to jack it up when you check for play in your front end. most people who do alignments jack it up from the lower control arms...even though the lower control arms is wrong on subarus. you can take it back to teh shop and tell them they are checking the front end the wrong way. tell them the suspension has to be "unloaded" in order to properly check it -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 20, 2011 Author Share Posted February 20, 2011 ok. so do you think they only noticed play casue they jacked it all like that... it was a drive on life and then little things came up below like you said. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 21, 2011 I Donated Share Posted February 21, 2011 Its likely thats what happened. Sent from my Android powered HTC HD2 -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 21, 2011 Author Share Posted February 21, 2011 one problem. today. on a snow covered road. it still sweaked.. not the tires. its the bearings or brakes Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 21, 2011 I Donated Share Posted February 21, 2011 your wheel bearings won't squeak. your brakes and tires will make that kind of noise though. just take it to the shop and get it fixed. i can't fix it for you over the internet. and get an alignment. I can almost PROMISE you thats your problem -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 22, 2011 Author Share Posted February 22, 2011 yea i know. im running a spare, a 1.5 inch lift and i hit stuff. alot Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 22, 2011 I Donated Share Posted February 22, 2011 So what are you trying to figure out? It would help if at first you come out and say all reliant information. Try and drive better. If you can't stop crashing into things, then maybe you should be driving. You probably bent something somewhere. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 22, 2011 Author Share Posted February 22, 2011 the sweak is gone. i got a car wash and it vanished Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 23, 2011 I Donated Share Posted February 23, 2011 Wtf -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
LuckyBob Posted February 23, 2011 Share Posted February 23, 2011 I'm still trying to figure out what a sweak is. The best Google could come up with is this: http://upload.wikimedia.org/wikipedia/en/8/8b/Sweak.gif Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 23, 2011 Author Share Posted February 23, 2011 squeak, dont be a smartass. Link to comment Share on other sites More sharing options...
LuckyBob Posted February 23, 2011 Share Posted February 23, 2011 As this response was all the rage in middle school; "at least I'm not a dumbass." [...]i recently just adjusted the tierod endlike like 1 degree at the most. now my car follows lines in the road. it always sweaked like this before i adjusted it it is just louder now. i checked on my levels. and they are fine now. yea i know. im running a spare, a 1.5 inch lift and i hit stuff. alot Case in point. Also: http://hyperboleandahalf.blogspot.com/2010/04/alot-is-better-than-you-at-everything.html. you need to go get your car aligned. You can't just adjust your tie rods and hope for the best. If your car is wandering following grooves in the road and your tires are squeaking while driving, your toe is SEVERELY out and you need a professional alignment. Your car is NOT safe to drive like this. Go get it fixed properly your wheel bearings won't squeak. your brakes and tires will make that kind of noise though.[...] So what are you trying to figure out? It would help if at first you come out and say all reliant information. Try and drive better. If you can't stop crashing into things, then maybe you should be driving. You probably bent something somewhere. , eleventy billion. Solid advice, thus far not followed. If you don't have access to an alignment rack, fork over the cash to get the car properly aligned. It's incredibly difficult and time consuming to do it yourself. Firestone usually charges about one and an half times the price of a regular alignment for a lifetime alignment deal; it pays itself off the second time you use it. Also, just to show that I'm an equal opportunity contributor, to broknindarkagain: it's "relevant," not "reliant" and "shouldn't," not "should." Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 23, 2011 I Donated Share Posted February 23, 2011 Lol sorry for the typos. One if my hands are prettt messed up and im onn ppain killers lol Sent from my Android powered HTC HD2 -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted February 23, 2011 Author Share Posted February 23, 2011 And im in highschool. they do not focus on spelling and have not since the 5th grade. plus my keyboard and my hands do not like each other. I often find myself pressing twice the amount of keys that i planned on. I seems like everyone in my age group has a hard time spelling. i think in a few years this may become a bigger problem. but for now, we just ask adults and use spell check. even one of my ex's that rights all the time and reads all the time is still a horrible speller. And i didnt want an alignment yet and im broke and this car is sucking money out of me.. ill get alignment done when i get my all seasons mounted. or if i do get another car i'm just gonna though some kinda bobcat tire on the car and weld the diffs and trailer it to the mud trails. Link to comment Share on other sites More sharing options...
