Andreu Posted December 23, 2007 Share Posted December 23, 2007 Can i put a 6.75" speaker in the front doors of a 2005 LGT? Link to comment Share on other sites More sharing options...
Mr. Ed Posted December 23, 2007 Share Posted December 23, 2007 with proper modification ther are alot of speaker sizes that you can put in the front doors Link to comment Share on other sites More sharing options...
FJuan Posted December 23, 2007 Share Posted December 23, 2007 +1, Even with my 6.5s I had to modify the hole by bending back the metal surround. With the 6.75s, you may consider cutting a larger opening. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Andreu Posted December 24, 2007 Author Share Posted December 24, 2007 what is the factory speaker size Link to comment Share on other sites More sharing options...
str8dwn Posted December 24, 2007 Share Posted December 24, 2007 factory is 5.25 i believe, but Quart 6.5s fit fine with no drilling or cutting (1" of Kartboy spacers though due to depth). Link to comment Share on other sites More sharing options...
OGG Posted December 25, 2007 Share Posted December 25, 2007 How much of a spacer can you use? I want to put some Cadence comps in my wife's car to replace her (blech!)Infinities. The problem is that they're 3" deep and the Infinities barely clear the window with a spacer. I have them angled like the factory speakers for better imaging. Link to comment Share on other sites More sharing options...
Jimbizzle Posted December 26, 2007 Share Posted December 26, 2007 factory is 5.25 i believe, but Quart 6.5s fit fine with no drilling or cutting (1" of Kartboy spacers though due to depth). Mb Quart? Which model? How about the rear doors? Link to comment Share on other sites More sharing options...
str8dwn Posted December 27, 2007 Share Posted December 27, 2007 My MB Quarts are the new PVF-216. I left the stockers in the rear doors disconnected. I have a 300/4 bridged @ 150x2 on them. Link to comment Share on other sites More sharing options...
Jimbizzle Posted December 28, 2007 Share Posted December 28, 2007 I was thinking of the PCE-216 but I don't want to get an amp. Do you think it's worth getting that component set without an amp? Link to comment Share on other sites More sharing options...
str8dwn Posted December 28, 2007 Share Posted December 28, 2007 Quarts are known to need lots of power, so keep that in mind. However, they should sound better than stock, but overall volume may suffer some due to the lower efficiency. Link to comment Share on other sites More sharing options...
