silentsnow31802 Posted January 3, 2015 Share Posted January 3, 2015 I just purchased a 2005 legacy gt. It seems that the running lights are using the headlight bulbs. If I turn on the running lights the headlights come on. If I turn on the headlights they just get a little brighter. I also own a 2009 outback and the headlights do not operate this way. The headlights and running lights are two separate bulbs. Wondering if this is normal for a 2005 or not? It doesn't seem normal but i know there have been minor changes between the 2005 and 2009 era. Link to comment Share on other sites More sharing options...
MrTris Posted January 3, 2015 Share Posted January 3, 2015 Yes, it's normal. Welcome, and check out the walkthroughs section to learn how to disable your DRLs, as they're the number one culprit for bulb outages.. Link to comment Share on other sites More sharing options...
silentsnow31802 Posted January 3, 2015 Author Share Posted January 3, 2015 Okay thank you very much. What's the purpose of the smaller set of bulbs in the 05 headlight assemblies then? In my 09 those are the DRLs and the others are only used as headlights. I always wondered why people wanted to disable the DRLs but seeing how my 05 is done I understand now lol. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 3, 2015 Share Posted January 3, 2015 yeah if the car uses headlamps as DRL, they typically run them at 6V or with LED pulse them so they are half brightness. Other cars like a Acura TL have separate bulbs that run at 12V Link to comment Share on other sites More sharing options...
jmfspecb Posted January 3, 2015 Share Posted January 3, 2015 I can't remember how years ago I did it, but I isolated the DRL circuit and installed a switch. I put the switch inside the top of the fuse box. So, you open the fuse box lid and the switch is on the top of the bottom of the dash - if that makes any sense. It also makes a HID conversion kit work easier. Subaru changed this design configure in the 08 models. So, there are fewer people as the years go on with this type of issue. Link to comment Share on other sites More sharing options...
