lepich Posted October 14, 2008 Share Posted October 14, 2008 Got a revised tune from Mike. He was doing a great job on my new setup, just want to share results. It may not be the final one, did not heard from him yet. Car feels great, borla cbe not only a sound mod. Here is what I have: Flex Up, Lachute catted DP, borla cbe, K&N drop-in, lightweight pulley Let me know what you think please.Thanks 2nd and 3rd gear runs http://koloskov.com/temp/new/3rd_TA_3_2.csv http://koloskov.com/temp/new/3rd_TA_3_1.csv http://koloskov.com/temp/new/2nd_TA3_2.csv http://koloskov.com/temp/new/2nd_TA_3_1.csv There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted October 14, 2008 Share Posted October 14, 2008 What's your altitude? Timing is being pulled all over the place. Log knock sum to find out where it's coming from. Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 14, 2008 Share Posted October 14, 2008 mickeyd2005...How do you display the links in excel? All his values are all bunched up. Fixed...Firefox does not see the link as an excel or csv file. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 14, 2008 Share Posted October 14, 2008 mickeyd2005, Should OP run learn viewer as well too or just a waste of time with the new knock counter feature in the new defs?? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
lepich Posted October 14, 2008 Author Share Posted October 14, 2008 Atlanta, GA: Elevation 738-1,050 ft (225-320 m) Here is the leraning view: http://koloskov.com/temp/new/leraning_view.jpg There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted October 14, 2008 Share Posted October 14, 2008 You need to get that fixed. IAM should have been 1.0 after a datalog. It's not 1.0 because you've got all kinds of knock in the high load region. Power is down too considering you are at 1000 ft elevation. Not sure why. Could be a host of reasons. Link to comment Share on other sites More sharing options...
lepich Posted October 14, 2008 Author Share Posted October 14, 2008 Thanks! Now I've loaded the original OTS TA tune Mike sent me, will post logs soon. First time it looked like too low boost to me, so i've asked for a tweak. But it might be the only safe tune I have to go with. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 14, 2008 Author Share Posted October 14, 2008 Ok, here is a new logs, from OTS TA tune for my setup: http://koloskov.com/temp/new/3rd_TA_Orig.csv http://koloskov.com/temp/new/2nd_TA_orig1.csv http://koloskov.com/temp/new/2nd_TA_orig2.csv http://koloskov.com/temp/new/2nd_TA_orig3.csv It was about 78F outside, intake tems were 93F-95F LV: http://koloskov.com/temp/new/learning_view_TA_Orig.jpg Looks better? There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Infamous1 Posted October 14, 2008 Share Posted October 14, 2008 mickeyd2005, Should OP run learn viewer as well too or just a waste of time with the new knock counter feature in the new defs?? The knock counter will let you know for sure if you knocked on that pull, however if it is learned liked the OP you would need to utilize the learning view. The knock counter used in combination (before/after runs) with the learning view is likely the best way to log. Link to comment Share on other sites More sharing options...
lepich Posted October 15, 2008 Author Share Posted October 15, 2008 Infamous1, what do you think of my last logs? Am I Ok to drive the car? Did not hear from Mike yet.. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Infamous1 Posted October 15, 2008 Share Posted October 15, 2008 Infamous1, what do you think of my last logs? Am I Ok to drive the car? Did not hear from Mike yet.. No it still needs to be fixed. Your load is way down causing you to run too much timing resulting in all kinds of knock and timing being pulled. I almost certain if you pull another learning view it will show even more learned correction. Link to comment Share on other sites More sharing options...
TPLGT Posted October 15, 2008 Share Posted October 15, 2008 Hmmm...I had no issues...Mike should be able to fix this... Rehab is for quitters. Link to comment Share on other sites More sharing options...
lepich Posted October 15, 2008 Author Share Posted October 15, 2008 Hope Mike will fix it. Thank you! There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 17, 2008 Author Share Posted October 17, 2008 Got the most recent realtime map update. Please tell me it looks decent:-) http://koloskov.com/temp/2nd_TA_RT_3_1_cold.csv http://koloskov.com/temp/2nd_TA_RT_3_2_cold.csv http://koloskov.com/temp/3rd_TA_RT3_1_cold.csv http://koloskov.com/temp/3rd_TA_RT3_2_cold.csv Learning view: http://koloskov.com/temp/LearningView_10-16-2008 10 43 43 PM.csv There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 18, 2008 Author Share Posted October 18, 2008 Bump! Really need an opinion form experienced tuner.. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 18, 2008 Share Posted October 18, 2008 Got the most recent realtime map update. Please tell me it looks decent:-) http://koloskov.com/temp/2nd_TA_RT_3_1_cold.csv http://koloskov.com/temp/2nd_TA_RT_3_2_cold.csv http://koloskov.com/temp/3rd_TA_RT3_1_cold.csv http://koloskov.com/temp/3rd_TA_RT3_2_cold.csv Learning view: http://koloskov.com/temp/LearningView_10-16-2008 10 43 43 PM.csv There is no knock showing, if that is what you want to know. The one file has real funny timing, but I am assuming that is the tranny shifting. I am no VF40 expert, so if you can run more timing, or more boost, or......................is kinda hard for me to give good advice. FWIW boost control and timing looks conservative and fairly solid. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
lepich Posted October 18, 2008 Author Share Posted October 18, 2008 Thank you, sir. At least now I know it is safe. I am waiting on what Mike is going to say. Interesting, acceleration is more even, I do not feel big push after 3200, as it use to be, its more linear, and much better after 4500 to a redline. Probably full catback is helping there. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
TPLGT Posted October 18, 2008 Share Posted October 18, 2008 Glad to see things are shaping up...TMIC is next! Rehab is for quitters. Link to comment Share on other sites More sharing options...
Infamous1 Posted October 18, 2008 Share Posted October 18, 2008 Thank you, sir. At least now I know it is safe. I am whaiting on what Mike is going to say. Interesting, acceleration is more even, I do not feel big push after 3200, as it use to be, its more linear, and much better after 4500 to a redline. Probably full catback is helping there. I though I replied here It feels more linear because he took a big chuck of timing out that was causing you to knock all over the place. Your boost is pretty low but you aren't going to get much more without a smaller pill or ebcs. I think he still has a little room for a bit more timing but right now your runs are clean. Link to comment Share on other sites More sharing options...
lepich Posted October 18, 2008 Author Share Posted October 18, 2008 BTW, could be whp calculated based on the logs? Curious to see what I have. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 18, 2008 Author Share Posted October 18, 2008 TPLGT, Which size of a pill do you have? As for a TMIC, it will be my next for sure. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 18, 2008 Author Share Posted October 18, 2008 Ok, I used more aggressive map from Mike, call it version 2. Car feels much stronger, if it would be a safe as well, I'll be happy ! Here they are: (68F outside, 75-77 intake temp) http://koloskov.com/temp/10_18_RT2/2nd_RT2_1.csv http://koloskov.com/temp/10_18_RT2/2nd_RT2_2.csv http://koloskov.com/temp/10_18_RT2/2nd_RT2_3.csv http://koloskov.com/temp/10_18_RT2/3rd_RT2_1.csv http://koloskov.com/temp/10_18_RT2/3rd_RT2_2.csv Learnign view: http://koloskov.com/temp/10_18_RT2/10_18_LV_RT2.png It seems that car is hitting a target boos (17.7 per Mike), no pill is necessary? There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 19, 2008 Author Share Posted October 19, 2008 TPLGT, was reading your tune thread again.. You've had around 19 psi of boost on a stock TMIC with PDX map, right? Is such boost was possible only beacuse of a smaller pill? I have the same setup plus a CBE, but 17 psi is max for me.. Feel jealous :-)) There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
TPLGT Posted October 19, 2008 Share Posted October 19, 2008 Hi yeah before I went stage 2 I had an Ecutek stage 1 tune. The Tuner could not get the car to boost so a smaller restrictor pill was added. I don't know what size it..sorry. Yeah I was using a PDX stage 2 map but when I bot the TMIC, I had Mike at TA make me one...so now I am running the TA map...car feels great!. Today I was on the highway doing 80 and I matted it..at WOT, I threw a CEL so I will be reading the code, clearing it and logging to see whagt happened.... I suspect if you put in a smaller pill, you will get much better boost...ask Infamous which size you should use. Rehab is for quitters. Link to comment Share on other sites More sharing options...
lepich Posted October 19, 2008 Author Share Posted October 19, 2008 Thank you, sir. CEL? Hope nothing serious there. Infamous1, what pill size you would reccomend? 1mm? 1.1? Was reading a lot, people suggest to go between 1mm to 1.2 mm, as stock pill is 1.25mm. (05 LGT) Correct me if I am wrong. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
