Turn signal problem (quick blinking)
I am having a problem with my turn signal, basically what is described here:
http://legacygt.com/forums/showthread.php/help-turn-signal-switch-132545.html
The bulbs are fine. The problem is isolated to the right side so I swapped bulbs with the left side (which work). The problem continues to be the right with the left working fine.
My issue is getting the turn signal stalk off to clean/replace. I messed with it a little bit today and undid 2 small screws but the stalk didn't budge. Is there something I am missing? Do I need to remove the steering wheel?
Thanks!
OK this is idagram for this series.
http://static.opposedforces.com/epc_img/366494983201.png
For future ref:http://opposedforces.com/parts/legacy/us_b11/
Also:http://www.main.experiencetherave.com/subaru_manual_scans/
Hope this helps.
O.
