monkeyposeur Posted January 23, 2013 Share Posted January 23, 2013 As some of you know I have a 22T that I want to swap into my 95 L. I have been considering doing a stroker hybrid build. However I am finding the stock 22T to be a lot of fun in my SS. So now I am considering swapping the stock 22T into the L. I know that most swaps require a harness merge. But I might be able to pull a complete wiring harness from a touring wagon as well as the 22T ecu. My question is instead of doing a merge couldn't I just swap the whole harness over? I'm not worried about going from obd2 to obd1. Since my L is from 95 I can still pass safety and emissions even if I swap to obd1. I am thinking about going this route because it will be a lot cheaper than going the stroker route and I have access to everything I would need to do a stock 22T swap. Of course a stroker build would be awesome but also way more expensive. Link to comment Share on other sites More sharing options...
subikid90 Posted January 23, 2013 Share Posted January 23, 2013 You will need to still merge for your dash equipment, lights, horns, trans, abs, etc. I have a very good feeling that the harnesses are not the same plugs for the above items. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2013 Author Share Posted January 24, 2013 I went to pull the harness from the touring wagon at the junkyard but it was gone! It was there Sunday. I figured I'd pull it just in case I decided to go the stock route. I did some research and it appears to be a pretty easy swap into a 1st gen. You just move some pins around and plug in the 22T ecu. The swap into a second gen appears to be a little more complicated like you said subikid90. Guess I'll just have to use my WRX harness and do the stroker build, lol. Didn't go home empty handed though. I found a nearly perfect, rust free passenger side fender for my SS. Only one tiny ding. The original one has a huge rust hole at the bottom that I don't care to fix. Link to comment Share on other sites More sharing options...
subikid90 Posted January 24, 2013 Share Posted January 24, 2013 Haha it could be worse lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
