SpecBlitzed Posted August 29, 2013 Share Posted August 29, 2013 04-present STi flywheel is something around 6 millimeters bigger and Subiemods told me it will fit my 07 Spec B. So will everything else??? I called the dealer FW, Clutch,PP, throw bearing. Clutch Kit $693+install =$943 Link to comment Share on other sites More sharing options...
rtbrjason Posted August 29, 2013 Share Posted August 29, 2013 Sti flywheels and clutches will fit your Spec B. I would use your stock flywheel or at least make sure you don't go too light on the flywheel. I put in an "ACT Streetlite" (15lbs) and it was for sure the worst mod I've done. I can't wait to put my OEM flywheel back in. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted August 30, 2013 Author Share Posted August 30, 2013 STi flywheel will fit. Everything else, I don't know. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 30, 2013 Share Posted August 30, 2013 Sorry.. Yes everything clutch related will fit your 07 spec B. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted August 30, 2013 Author Share Posted August 30, 2013 04-13 Factory Subaru STi clutch kit internals in my 07 Spec B. Can I verify this a 100% install?!? Link to comment Share on other sites More sharing options...
rtbrjason Posted August 30, 2013 Share Posted August 30, 2013 Yes... I have an 04 Act HDSS Clutch kit and Flywheel in mine.. Complete bolt up, no modification install. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted August 31, 2013 Author Share Posted August 31, 2013 Ordering from the Dealership. Thanks Link to comment Share on other sites More sharing options...
