ChefRacer Posted January 9, 2013 Share Posted January 9, 2013 So I just picked up a turboxs intake for my 05 lgt. It says that it's for an 08-10 wrx and they are mostly the same as our cars so I figured that it should fit the same. I Didn't realize that the maf sensor was different between the two in shape and mounting points. So my question is, are the connections the same between the older and newer versions? If I find a newer sensor, will it plug and play with just maf scaling to get it all setup? Thanks for the help, I appreciate any advice you can throw my way. Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
SCASEYS Posted January 9, 2013 Share Posted January 9, 2013 intake, lololololol did your tuner tell you to get one? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 Fmic Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
SCASEYS Posted January 9, 2013 Share Posted January 9, 2013 OK, still is it a CAI or a shortram ? does the MAF bolt right in? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 Trust me, I wanted to stick with the stock airbox but I had heard mixed reviews of the racer x so I went with the turbo xs fmic which requires an intake. I modified an hks intake which was made for an older wrx initially b/c I couldn't afford anything decent at the time. I'm not a noob and I am my tuner. I just want to know if the newer maf is plug and play or if I need to do some wiring modifications Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 Yes the maf bolts in, but the bolt pattern is different and the hole for the sensor is smaller Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
SCASEYS Posted January 9, 2013 Share Posted January 9, 2013 http://legacygt.com/forums/search.php?searchid=11492522 log your AFR, if it's off you will need to do MAF scaling at least that is what search has provided me with I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 I know how to scale a maf, that's not my question at all. I'm asking if the newer maf will plug into the old maf harness without modification. Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
GTTuner Posted January 9, 2013 Share Posted January 9, 2013 Ok, it's going into an 05, what year WRX did it come out of? I will get you a connector pin out. 08-10, correct? Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 Yeah Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
ChefRacer Posted January 9, 2013 Author Share Posted January 9, 2013 I might just make up an adapter plate to use my current maf if it doesn't connect up. Might be easier Sent from my HTC One X using Tapatalk 2 Link to comment Share on other sites More sharing options...
GTTuner Posted January 9, 2013 Share Posted January 9, 2013 Looking at the two schematics I believe the sensor operates the same but the terminals MIGHT need to be swapped around in the connector. PM me if you want the schematic for both years. Link to comment Share on other sites More sharing options...
