Car won't start after a month
I was away from my legacy for a month and it didn't have any starting issues when I left, come back thought the battery was dead so I charged it up and now all dash lights and chimes will come on but nothing else happens when the key is turned. What should I check next?
Had it hooked up to one of those portable battery chargers/jump starters, which was plugged into an outlet, let it charge for a couple hours and tried to start it with it still plugged in. It's very possible that the battery could be completely shot. I should have unplugged it before I left.
Get the battery tested, or just replace it. Most chain auto parts stores will test you battery for free. If the battery was weak to begin with letting it sit for a month could be what cinched the deal. If the battery is bad it may not accept a charge. Trickle chargers, and run of the mill jump boxes won't always work if the battery is toast.
