06LegacyRBP Posted July 10, 2013 Share Posted July 10, 2013 Coolant is leaking from the end of the hose that is connected to the engine from the radiator. Need help on what to do. Dont see any cracks or holes at all. Is this a bad sign or not that big of deal?? Please help thanks! Link to comment Share on other sites More sharing options...
ewaugh Posted July 10, 2013 Share Posted July 10, 2013 Well it could turn into a big deal if you run low on coolant. My advice would be to replace the hose and change out that POS hose clamp. Check your other radiator hoses as well. Link to comment Share on other sites More sharing options...
ctlex Posted July 11, 2013 Share Posted July 11, 2013 No need to replace the hose if its still in good shape. Remove that end of the hose, clean off the corrosion with a scotch brite pad and put a screw type hose clamp on. Link to comment Share on other sites More sharing options...
