volodyalysak Posted May 5, 2013 Share Posted May 5, 2013 LGT 2005, 149K miles EJ257 shortblock at 147K New LCA bushings, New front CV axles (cardone) New brakes Tranny oil flush only drain and fill My problem D-When cold, really bad vibration when in drive while brakes pressed D-When hot, still vibrates, but much less N- no vibration what so ever R - same as D when cold a lot of vibration P- no vibration what so ever In D or R with no accelerator pressed car moves forward or reverse, and i have to hold brakes firmly, i know it is suppose to move, but there should be minimum brake work to stop it. I recall having issues with gas pedal, i'we cleaned contacts back than, and no more engine codes, but with my romraider logger it shows, that without pressing gas pedal throttle plate opens to 7-8 %. I am thinking 3 possible causes: 1. CV Axles not beeing original, which may cause vibrations 2. Something loose or going out, (mounts, clutch in tranny etc) 3. My gas pedal assembly needs to be replaced/adjusted because it always stays at 7-8% at idle or in gear. Thank you guys for all input, i need to get this fixed, it drives me nuts. Link to comment Share on other sites More sharing options...
volodyalysak Posted May 5, 2013 Author Share Posted May 5, 2013 Bump Link to comment Share on other sites More sharing options...
tdelker Posted May 6, 2013 Share Posted May 6, 2013 This is classic 'bad' axle syndrome. Get an OEM replacement. Link to comment Share on other sites More sharing options...
Gex Posted May 6, 2013 Share Posted May 6, 2013 +1 for bad axle, fairly common on the cheap replacements. Link to comment Share on other sites More sharing options...
volodyalysak Posted May 6, 2013 Author Share Posted May 6, 2013 Ok, that what i was hoping to hear, should i get used subaru axles and rebuild them ? Link to comment Share on other sites More sharing options...
volodyalysak Posted May 6, 2013 Author Share Posted May 6, 2013 I don't have money to spend at the moment, but used subaru axles run 130 a pair. New ones much more Link to comment Share on other sites More sharing options...
Gex Posted May 6, 2013 Share Posted May 6, 2013 Still got the old one? If its just a blown boot. Just reboot it. The kit is like $30. Link to comment Share on other sites More sharing options...
rob-2 Posted May 7, 2013 Share Posted May 7, 2013 What kind of vibration? Is it in sync with the idle? Do the revs drop? Does the cabin shake? Does the idle get lumpy? Link to comment Share on other sites More sharing options...
volodyalysak Posted May 7, 2013 Author Share Posted May 7, 2013 1.=- vibration from the drivetrain, when engaged 2- at idle there is no vibration 3 my revs actually stay at 1000-1100 even when car is warmed up, don't know why 4. yes cabin shakes 5. At idle i can feel some rpm play 1000 to 1050 and back, sounds normal, but not sure \ Hope it helps Link to comment Share on other sites More sharing options...
06legsleeper Posted May 7, 2013 Share Posted May 7, 2013 most likely what was said above... bad axel.... i replaced both of my front axels , only i got mine from napa ( buddy is a mananger there ).. i havnt had one problem with them yet and its been 5 months Link to comment Share on other sites More sharing options...
rob-2 Posted May 7, 2013 Share Posted May 7, 2013 most likely what was said above... bad axel.... i replaced both of my front axels , only i got mine from napa ( buddy is a mananger there ).. i havnt had one problem with them yet and its been 5 months Is there any other way to confirm they are bad axles? Link to comment Share on other sites More sharing options...
rob-2 Posted May 7, 2013 Share Posted May 7, 2013 1.=- vibration from the drivetrain, when engaged 2- at idle there is no vibration 3 my revs actually stay at 1000-1100 even when car is warmed up, don't know why 4. yes cabin shakes 5. At idle i can feel some rpm play 1000 to 1050 and back, sounds normal, but not sure \ Hope it helps This sounds a lot like the idle problem I'm having. I can feel a slight 'lump' when not in D or R. Once in either gear I would get an RPM drop until the motor recovers. While in gear and stopped, it feels like a miss fire and with the A/C on the cabin will give a shake when the compressor kicks in. I'm not sure about my axles but tomorrow I'm having it put up on a lift to check the following: - compression/leak down - motor mounts - axles Link to comment Share on other sites More sharing options...
tdelker Posted May 7, 2013 Share Posted May 7, 2013 To Volo: No money - then get a used axle from a junk yard. You can always reboot when the boot tears. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2013 Share Posted May 7, 2013 A new axle from the auto parts store is like $80.00 OP you say you only get the vib when the car is moving. Some one else here recently is may be having propeller shaft issues. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Alex609 Posted May 7, 2013 Share Posted May 7, 2013 bad axle Link to comment Share on other sites More sharing options...
Alex609 Posted May 7, 2013 Share Posted May 7, 2013 also could be a damaged tie rod Link to comment Share on other sites More sharing options...
VermontGT Posted May 8, 2013 Share Posted May 8, 2013 http://legacygt.com/forums/showthread.php/you-buy-autozone-axles-206188.html Link to comment Share on other sites More sharing options...
volodyalysak Posted May 8, 2013 Author Share Posted May 8, 2013 A new axle from the auto parts store is like $80.00 OP you say you only get the vib when the car is moving. Some one else here recently is may be having propeller shaft issues. Well, i got 2 brand new axles from auto parts store, now i have vibration And i have vibration not while moving, but when in D or R with brakes pressed, adter i release brakes and start moving like 0.5 mph noise is gone. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 8, 2013 Share Posted May 8, 2013 What is your idle speed/rpm ? Is it to low ? I guees you have checked the fluid level in the tranny ? Have you had the tranny fluid changed when it was called for ? ClimberD may be your next bet, he's good with 5eat's, I'm just guessing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted May 8, 2013 Share Posted May 8, 2013 Well, i got 2 brand new axles from auto parts store, now i have vibration And i have vibration not while moving, but when in D or R with brakes pressed, adter i release brakes and start moving like 0.5 mph noise is gone. time to see a mech about this... Link to comment Share on other sites More sharing options...
