Buzzman Posted April 26, 2013 Share Posted April 26, 2013 The car is an auto. It started two days with 5th gear spiking in rpm's as I would shift into it. The car would impart the sensation that I was in boost, but wouldn't go anywhere. This led me to believe that the tranmission was slipping. However, earlier today, my fifth gear became totally unresponsive, as if I were in neutral. In addition, the car promptly threw a P0700 code. Now my car can't shift into fifth and I have no idea what to do. Any insight to what the problem may be? Thanks. Link to comment Share on other sites More sharing options...
rob-2 Posted April 26, 2013 Share Posted April 26, 2013 I'm wondering if you've completely burnt out that gear by say WOT in 5th? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 26, 2013 Share Posted April 26, 2013 I'm wondering if you've completely burnt out that gear by say WOT in 5th? Could be. I've heard people loosing their 5th gear on the forum. That was on manual trans though. Apparently, that gear is not as tough to handle lots of load. That's my understanding anyway. So it is a good idea to avoid WOT in 5th. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 26, 2013 Share Posted April 26, 2013 Here is a thread about what I've just mentioned: http://legacygt.com/forums/showthread.php/blown-5th-gear-149228.html Link to comment Share on other sites More sharing options...
Buzzman Posted April 26, 2013 Author Share Posted April 26, 2013 I hope it isn't that! Though, I didn't hear a pop when it occurred, perhaps that may or may not be a good thing? Would that require a whole new transmission? BTW, I almost never ride fifth up high into the rpm's. Link to comment Share on other sites More sharing options...
rob-2 Posted April 26, 2013 Share Posted April 26, 2013 Tell us how you were driving when it happened.... throw us a bone here. Link to comment Share on other sites More sharing options...
Buzzman Posted April 26, 2013 Author Share Posted April 26, 2013 Sorry. I was driving normally, around 40 mph and the car just wouldn't allow fifth to engage, no pop or noise anywhere. The car is sitting in my driveway right now until I can take it to the dealer. Link to comment Share on other sites More sharing options...
rob-2 Posted April 26, 2013 Share Posted April 26, 2013 You're probably looking at a new tranny unless rebuilding it is cost effective. With metal in their, I'd avoid doing a bunch of driving. Link to comment Share on other sites More sharing options...
Buzzman Posted April 26, 2013 Author Share Posted April 26, 2013 Hmm, being a college student nothing is really cost effective. I thought the tranny would be safe until I graduated; I only have 86,000 on the car. If I were to sell it, would you suggest first fixing the tranny? Link to comment Share on other sites More sharing options...
rob-2 Posted April 27, 2013 Share Posted April 27, 2013 You might be able to pick up a tranny from a junk yard. You're going to take a hit on the car, it in fact has a blown gear. Get it looked at for sure. Link to comment Share on other sites More sharing options...
Buzzman Posted April 27, 2013 Author Share Posted April 27, 2013 Thanks for the help. I already set an appointment up with Miller Subaru so I'll report back. Would you suggest letting the dealer install it? Link to comment Share on other sites More sharing options...
rob-2 Posted April 27, 2013 Share Posted April 27, 2013 Thanks for the help. I already set an appointment up with Miller Subaru so I'll report back. Would you suggest letting the dealer install it? dealers are typically very expensive to do any work. Friends + beer is how I'd do this project. Link to comment Share on other sites More sharing options...
Buzzman Posted April 27, 2013 Author Share Posted April 27, 2013 It's unfortunate, but I don't have any friends who would even be able to tackle that kind of task. Would it be worth it to swap a 6 speed in at this point? I plan on keeping the car as long as my financial situation permits. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 27, 2013 Share Posted April 27, 2013 A 6spd swap will be costly. If you really want to do it, give rallispec a call. Link to comment Share on other sites More sharing options...
Buzzman Posted April 27, 2013 Author Share Posted April 27, 2013 If it's costly then I would probably not go that route; I was assuming it was comparable in price. Would Rallispec be less expensive than the dealer, stoplight? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 27, 2013 Share Posted April 27, 2013 Can't say for sure. Fixing your 5eat will definitely be cheaper than a 6spd swap though. Link to comment Share on other sites More sharing options...
Buzzman Posted April 27, 2013 Author Share Posted April 27, 2013 When you say fixing, are you suggesting I fix my prexisting tranny instead of picking up a used one? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 27, 2013 Share Posted April 27, 2013 You could go either way...either rebuilding your current trans or betting that the used trans you purchase will be reliable. Unfortunately there's no path here that won't result in a lot of money changing hands. You could however save a lot of money by pulling the trans yourself and taking it to a shop. Link to comment Share on other sites More sharing options...
Buzzman Posted April 27, 2013 Author Share Posted April 27, 2013 I have the time, but neither the space nor the knowledge to be able to pull my trans. So, I would presume building my current tranny would be the best best? That way I know what's going into it. Is there anything you would suggest upgrading or reinforcing if do indeed rebuild it? Sorry for the litany of questions. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 27, 2013 Share Posted April 27, 2013 You could definitely look into the climberd valve body upgrade. If you plan on modifying your trans, going with a independent Subaru shop is the way to go. Most dealers don't like to modify cars from the stock specs. Give SJ Suby Works a call. They're a newer shop, but the owner Ralph has been working on Subarus for a long time. They're located in Runnemede. I should've thought of that earlier. Link to comment Share on other sites More sharing options...
dudeondacouch Posted April 27, 2013 Share Posted April 27, 2013 i read the title and though it was about the television show on BBC. i popped in to agree. Link to comment Share on other sites More sharing options...
Buzzman Posted April 29, 2013 Author Share Posted April 29, 2013 Took it to the dealership - turned out to be a problem with the solenoid. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 29, 2013 Share Posted April 29, 2013 Took it to the dealership - turned out to be a problem with the solenoid. cheap fix then? Link to comment Share on other sites More sharing options...
Buzzman Posted April 29, 2013 Author Share Posted April 29, 2013 Gotta love dealerships. They called me back, and told me that there is indeed a problem with the transmission and it needs to be rebuilt. They offered to rebuild the tranny for $2000. Does that sound like a good deal? I'm going to call the place stoplight suggested before I make any final decision. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 29, 2013 Share Posted April 29, 2013 Gotta love dealerships. They called me back, and told me that there is indeed a problem with the transmission and it needs to be rebuilt. They offered to rebuild the tranny for $2000. Does that sound like a good deal? I'm going to call the place stoplight suggested before I make any final decision. . Sorry to hear. Link to comment Share on other sites More sharing options...
