suby0624 Posted June 10, 2012 Share Posted June 10, 2012 2005 lgt. Has a 2 yr old Rad in it. I first took it to a local shop and they did a regular flush which did nothing my cool and looked liked rust. But after they did that it would not go above 3/4 on the temp gauge. So I took it to another shop that deals with subies about 10 miles away never hit the red never even went over 3/4 then. The heat was blowing very hot and then after they flushed out every component of the cooling system put a 160 degree t-stat in still overheating. Top Rad hose gets hot and hard. I think the water pump is working because I was getting hot heat and never overheated and I don't see any leaks near the hg. Do you think it could be air bound. The needle hits red before the t-stat housing gets up to 160. Could it be a defective t-stat? Need help. Car has about 100k about 40k on the short block. Link to comment Share on other sites More sharing options...
Ultrasounddude Posted June 10, 2012 Share Posted June 10, 2012 My son had this problem and turned out to be catted down pipe clogged with particles. Got a new high flow catted DP, problem solved. Link to comment Share on other sites More sharing options...
Jah Soldier Posted June 11, 2012 Share Posted June 11, 2012 How about the lower radiator hose, is it hot also? And the fans are working? Link to comment Share on other sites More sharing options...
