svxak47 Posted August 8, 2015 Share Posted August 8, 2015 Which oil filter would be recommended for a 2005 gt? So far Ive seen Bosch 3300 Fram 6607 Mobil 1 M1-108 It seems to me all these filters are tiny...what are you guys running and which part # and brands for more capacity. Thanks Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 8, 2015 Share Posted August 8, 2015 Buy an oem for newer subaru ej25 like the 2010 forester or oem for your car you can get them in packs on amazon for cheap. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 8, 2015 Share Posted August 8, 2015 09+ RX8 filter PN # N3R1-14-302 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
svxak47 Posted August 8, 2015 Author Share Posted August 8, 2015 Would using a oil filter specified for a different car model void my warranty though? I purchased a lifetime warranty and dont want to run into that issue if it comes up since Ill be doing my own oil changes. I just dont like the smallish filters for our cars. Link to comment Share on other sites More sharing options...
Mike07LGT Posted August 8, 2015 Share Posted August 8, 2015 Oem Subaru filter is the best way to go 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 8, 2015 Share Posted August 8, 2015 The RX8 Filter is the same filter Subaru used for the FA motors before they shifted to the crappy Honeywell Fram filters produced in the US. Besides they cannot void your warranty unless they can prove that particular part didn't meet specs and was also the singular cause of the failure. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
BigBad Posted August 8, 2015 Share Posted August 8, 2015 With a lifetime warranty make sure you document those oil changes you are doing yourself. For me I use Wix / Napa gold oil filters. Link to comment Share on other sites More sharing options...
turboboost Posted August 9, 2015 Share Posted August 9, 2015 I've been using NAPA gold filters lately. Link to comment Share on other sites More sharing options...
HLOwner Posted August 10, 2015 Share Posted August 10, 2015 More important to change the oil often. If you change the oil and filter often and use a good filter. it doesn't matter what filter you use, I still err on the safe side and use Bosch Longlife even though I change my oil every 3k miles. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 10, 2015 Share Posted August 10, 2015 More important to change the oil often. If you change the oil and filter often and use a good filter. it doesn't matter what filter you use, I still err on the safe side and use Bosch Longlife even though I change my oil every 3k miles. actually using a filter with the correct bypass valve setting is quite important. Not all filters have the correct bypass valve settings. Purolator stands out as one who lists lower than correct PSI. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
whitrzac Posted August 10, 2015 Share Posted August 10, 2015 You keep on believing that the 'oem' filter isn't built by the lowest bidder... Link to comment Share on other sites More sharing options...
Max Capacity Posted August 10, 2015 Share Posted August 10, 2015 Would using a oil filter specified for a different car model void my warranty though? I purchased a lifetime warranty and dont want to run into that issue if it comes up since Ill be doing my own oil changes. I just dont like the smallish filters for our cars. The RX8 Filter is the same filter Subaru used for the FA motors before they shifted to the crappy Honeywell Fram filters produced in the US. Besides they cannot void your warranty unless they can prove that particular part didn't meet specs and was also the singular cause of the failure. Look up the Magnuson-Moss Warranty Act it covers this. FWIW, I used Fram filters and 5w-30 Mobil 5000 or Shell, or Exxon oil, sometimes in warmer weather Rotella 15w-40, that was on sale at Walmart for the first 154,000 miles. Never had a oil related issue. I got 142,000 miles on the OEM turbo. The important thing it to change the oil and filter and keep records of what you used and the mileage and date. I keep a little pocket note book with everything I do on the car. The dealer copied it once to cover a tranny rebuild. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
svxak47 Posted August 15, 2015 Author Share Posted August 15, 2015 I got the Rotella T6 and using the Bosch 3300 Link to comment Share on other sites More sharing options...
Soarin Posted August 15, 2015 Share Posted August 15, 2015 I've been using K&N Gold oil filters for years. The welded nut helps since I have a Rallitek skidplate that makes things slightly more diffficult to get to. Link to comment Share on other sites More sharing options...
paul7ro Posted September 4, 2015 Share Posted September 4, 2015 The oem filter is good enough. No need to get aftermarket ones. Link to comment Share on other sites More sharing options...
rapture Posted September 4, 2015 Share Posted September 4, 2015 Wasnt there a thread on this already Where the guy gutted every filter on the market pretty much? I seem to remember it was the purolator pure one" That was the best? Btw i totally agree with above statements , as long as you change them often Your fine And check your oil often! In the morn before starting Link to comment Share on other sites More sharing options...
Vetteman Posted September 4, 2015 Share Posted September 4, 2015 Been running Mobil 1 110 filters for a long time. Same pressure settings as the 108 (OEM equivalent), but a longer body. OEM on various Honda/Acura V6's I think. Plus M1 High Mileage 10-40 from Wally's. Pretty sure the current OEM filter supplier is Fram - there was a thread on the topic a while back. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 4, 2015 Share Posted September 4, 2015 Wasnt there a thread on this already Where the guy gutted every filter on the market pretty much? I seem to remember it was the purolator pure one" That was the best? Btw i totally agree with above statements , as long as you change them often Your fine And check your oil often! In the morn before starting Unless they have updated their parts the Purolator filter has WAY too low of a bypass value setting. It's like 14psi instead of 23psi. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
