Help with seized rear adjustment bolts
robmat
I took the wagon in for an alignment and was told the cam bolts/nuts in the rear are seized and the shop could not perform the alignment for fear of breaking the bolts. They recommended I treat the bolts with PB blaster and attempt to free them myself before bringing the car back. I've been at it for about a week now alternating PB Blaster and WD Blue Torch. I've also tried heating the nuts with no luck.
Anyone have any suggestions? If I took it to the dealer for an alignment, would they be any better suited for the job?
Thanks so much
Robmat
Don't you have another thread on this? :lol:
How much heat are you applying to the nuts and for how long? Are you trying to turn the nut right after heating?
It's possible that you'll need to order a new set of nuts and bolts and grind the old ones off.
  • 2 weeks later...
For what its worth, I would suggest trying a different penetrating oil product before resorting to grinding them off. I have had excellent results with CRC FREEZ-OFF (sp?).
Auto parts stores as well as WalMart usually carry it.
With this, you flood the bolt/nut for maybe 10 seconds, let it sit for a few, and then spin it off. The refrigerant cools the thread joint, breaks the rust bond, and allows the penetrating oil to wick in.
I was at the same point as you trying to remove studs from an up-pipe, including the torch heating - no dice. Tried the FREEZ-OFF and they spun off like I had just installed them yesterday!
We use a sawzall on them and then replace with new bolts...
-Mike Paisan
http://www.pbase.com/paisan/image/153798190.jpg
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Are you talking about the toe adjustment bolts? The dealer will cut out and replace the control arms because they a typically seized in the bushing. I replaced my bushings but still couldn't get with in a good range cause its a lowered outback. I went with the megan adjustables arms for toe adjustment and the whiteline bushing kit for camber adjustment. oh and what the others said sawzall is your best bet. Good luck.
