Help identifying part
http://legacygt.com/forums/attachment.php?attachmentid=226776&d=1458594276
07 LGT.
I have a vac leak coming from the small cover circled in red. Just in front of the turbo, under the manifold.
Any help identifying this as I am trying to find the gasket?
I've checked OF, can't seem to find it listed.
That is definitely a TGV blockoff plate. Ordinarily there would be the TGV sensor there which would then have the shaft with a seal as seen on the bottom of the 2nd one in from the left. OEM TGV's on left JDM deletes on right.
My guess is when the delete was done the seal wasn't perfect after taking out the shafts and there wasn't enough or any JB weld used to seal it.
2005 Vader Wagon
Material Tests on Ringland Failure Piston
I should have held off and purchased a wagon instead of the spec.B
14120 is the motor. The sensor is the smaller one and is near the turbo on the passenger side. You may have the "cheap" delete done where just the motors are deleted and the shaft and plates are left in in the open position.
2005 Vader Wagon
Wouldn't this normally throw a CEL if it was rigged this way?
And I don't have any extra plugs dangling.
I didn't do the delete and didn't think it had been done. So there was no tune for it.
I have to dig into this and figure out what the heck is going on.
Easy enough the see if the motors are in place without tearing anything apart?
Topfeed TGV deletes use a different motor then the sidefeeds on 05-06 cars. He probably still has his TGVs.
Pic of 07 STI Topfeed TGV. You can see that same plate on the backside. The 05-06 sidefeeds have motors/sensors on both the back and front.
07+
http://img.photobucket.com/albums/v384/trdvibe/Scanned%20Pics/DSC_2498.jpg
Older Style
http://img.photobucket.com/albums/v62/sirgvtec/DSCN2392.jpg
Thanks for the help!
I was sort of wondering about the 05/06 vs the 07-09's. Looks like I would have to order the full assembly just for a gasket from what I have found. Might have to RVT, rather not.
EDIT:
I guess I can just crack it open and RTV.
