EK_YYC Posted April 18, 2013 Share Posted April 18, 2013 Does anyone know where I can splice Into my tach signal? I'm wiring up my failsafe/data logger in my 06 LGT and can't find the correct wire. Any advice is appreciated. Link to comment Share on other sites More sharing options...
CapSlo Posted April 19, 2013 Share Posted April 19, 2013 http://legacygt.com/forums/showthread.php/pop-quiz-ecu-wire-colors-21909.html?t=21909 Link to comment Share on other sites More sharing options...
EK_YYC Posted April 19, 2013 Author Share Posted April 19, 2013 Thank you! Link to comment Share on other sites More sharing options...
derkahn Posted January 17, 2014 Share Posted January 17, 2014 Does anyone know where to tap into tach signal at gauge cluster? assuming that is easier.. Installing a ecliptech shift-i and if I can run 12 inches of wire from cluster that sounds better than running 4ft of wire from passenger footwell.. Link to comment Share on other sites More sharing options...
derkahn Posted January 19, 2014 Share Posted January 19, 2014 I am sure our cars have more than one pink wire.. but might I assume if I see a pink wire feeding into gauge cluster that it is probably the same one coming from the ecu? Link to comment Share on other sites More sharing options...
AkumaMax Posted January 24, 2014 Share Posted January 24, 2014 ours as far as I remember only has the one. From off the top of my head the tach signals were either the pink or purple wire. 2 places to tap into. Under steering wheel there is a black box that says something like AT/MT on there you will see the pink wire. There is another tap point behind the tach. I will say that getting to it is a little bit of a fuss but yes there is a point. It would be on the 22pin green connector on the drivers side of the rear gauge cluster. Link to comment Share on other sites More sharing options...
SSpeed Posted October 22, 2016 Share Posted October 22, 2016 I'm having a tough time finding the tach wire. I pushed a wire into the connector with the pink wire that's second from the end here, but it doesn't seem to work with the shift light. There's also another pink wire with a silver stripe. Is that pink wire second from the end definitely the tach wire? http://i85.photobucket.com/albums/k62/dil222/20161021_180712.jpg Link to comment Share on other sites More sharing options...
SSpeed Posted October 22, 2016 Share Posted October 22, 2016 According to the service manual, the tach signal is the 3rd wire in (A20), which looks to be a pink wire with silver stripe. http://i85.photobucket.com/albums/k62/dil222/meter1.png http://i85.photobucket.com/albums/k62/dil222/meter2.png Link to comment Share on other sites More sharing options...
