retslo Posted May 8, 2015 Share Posted May 8, 2015 I'm using the 2007 Legacy GT clutch/single mass flywheel (from Fred Beans) but we are having issues with 1/2" being too short. When you engage clutch it comes off transmission. My mechanic is scratching his head on why would that be. Any suggestion guys? I can't be only one that had that issue of this not working correctly. Thanks in advance. Link to comment Share on other sites More sharing options...
FJuan Posted May 8, 2015 Share Posted May 8, 2015 ^^^ Yup, you'll have to have all 3 pieces for it to work. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
retslo Posted May 8, 2015 Author Share Posted May 8, 2015 I got clutch + flywheel + TSK3 kit. Which 3 are you referring to? Clutch kit had disk, pressure plate and flywheel in it. Yet we are still short Link to comment Share on other sites More sharing options...
FJuan Posted May 9, 2015 Share Posted May 9, 2015 Are you sure the clutch & flywheel is for the GT model? The 2.5i kit is different than the GT kit. May have to pull it off and measure the flywheel and clutch to see if it has the same distance as the OEM. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
retslo Posted May 10, 2015 Author Share Posted May 10, 2015 Yeah I think that is where I'm going to check on Monday. It is unlikely that Fred Beans sent me wrong parts but it is worth checking. These are part numbers that should be in there: 30100AA883 (Disk), 30210AA690 (Pressure Plate) and 12342AA090 (Flywheel) - I was told by Subaru those should be GT parts. Anyone knows 2.5i parts? It would make sense that new kit should have same distance as OEM otherwise it is wrong kit. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2015 Share Posted May 10, 2015 I got my 07-09OEM flywheel and Spec clutch from "underdog" everything works great. You need to have 07-09 GT FW and clutch kit. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
retslo Posted May 11, 2015 Author Share Posted May 11, 2015 That is exactly what I ordered. I'll be getting some answers today. Either this will be all clear (wrong parts) or ? Thanks for responding. Link to comment Share on other sites More sharing options...
jonah_ow Posted June 20, 2015 Share Posted June 20, 2015 Did you ever find any resolution to this issue? I am having the same problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2015 Share Posted June 23, 2015 Did you PM him ? the OP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
retslo Posted August 25, 2015 Author Share Posted August 25, 2015 Sorry guys - update here. Yes all worked fine once I got my buddy mechanic involved. First place managed to bend and damage few parts but in the end all parts fit. Clutch is so much nicer than original and of course no noise like aftermarket ones. Hopefully that helps somebody! Link to comment Share on other sites More sharing options...
