billvegaschris Posted September 20, 2015 Share Posted September 20, 2015 1996 Legacy LS tested alternator and its good started tested good battery tested good changed the cables and got crank still no start not sure what to check now thanks for the help Link to comment Share on other sites More sharing options...
ehsnils Posted September 21, 2015 Share Posted September 21, 2015 Two things to check: Do you have spark at the spark plugs?Do you have fuel pressure? Link to comment Share on other sites More sharing options...
twisty Posted September 21, 2015 Share Posted September 21, 2015 air, fuel spark. the three things you need for an engine to run. youve checked one, now check the other two. Link to comment Share on other sites More sharing options...
stevenva Posted September 23, 2015 Share Posted September 23, 2015 Want to throw a sensor at it? Crank sensor. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
meier motor sports Posted September 23, 2015 Share Posted September 23, 2015 try a short spray of carb / choke cleaner in the intake and see if it trys to start. if it trys to start look for a fuel issue. if it still does not try to start, check the ignition system. Link to comment Share on other sites More sharing options...
brokentv Posted October 2, 2015 Share Posted October 2, 2015 I want to second checking fuel pressure. I was having a crank but no start, I could get it to start but it took so long it got to the point where it was draining the battery just to get it started. It turned out to be the fuel pump. When you turn the key to on. Listen for the fuel pump priming. If you hear nothing your fuel pump might be the problem. I went to the junk yard and got the whole fuel sending unit and swapped it $40. Probably one of the easiest parts to replace on these cars. Just be careful not to tear the fuel line end when getting the hose off the fuel pump. Now sometimes my car will start before it even gets the chance to actually crank. Quicker than a brand new car. Link to comment Share on other sites More sharing options...
stevenva Posted October 2, 2015 Share Posted October 2, 2015 No reply from O.P? Unsubscribe RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
