Qckslvr Posted June 19, 2013 Share Posted June 19, 2013 All I did was copy the factory ROM to the laptop using ECUFlash, no tuning, or any funny business. When I get in the car to drive today, the RPMs are sluggish; a quick jab of the throttle produces a slow rise in RPM. I noticed it the most when I went to rev-match... Any ideas? Link to comment Share on other sites More sharing options...
chimera Posted June 19, 2013 Share Posted June 19, 2013 What does LV show? Link to comment Share on other sites More sharing options...
heiche Posted June 19, 2013 Share Posted June 19, 2013 dumb question: did u plug in the green test connectors and forget to disconnect them? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Qckslvr Posted June 20, 2013 Author Share Posted June 20, 2013 dumb question: did u plug in the green test connectors and forget to disconnect them? AFAIK, these are not present on 08 models right? Link to comment Share on other sites More sharing options...
Qckslvr Posted June 20, 2013 Author Share Posted June 20, 2013 What does LV show? I havent run a LV on it since i pulled the ROM, should I? What would I be looking for? Link to comment Share on other sites More sharing options...
chimera Posted June 20, 2013 Share Posted June 20, 2013 AFAIK, these are not present on 08 models right? Present, but not needed. I havent run a LV on it since i pulled the ROM, should I? What would I be looking for? Take an LV and post the screenshot up here. Enable DTC reader too. It will help determine any "funny business" Link to comment Share on other sites More sharing options...
ssbtech Posted June 20, 2013 Share Posted June 20, 2013 Any chance you reset the ECU? Link to comment Share on other sites More sharing options...
chimera Posted June 20, 2013 Share Posted June 20, 2013 ^ good point Link to comment Share on other sites More sharing options...
BlazeRex Posted June 20, 2013 Share Posted June 20, 2013 Probably reset the ECU. Give it a couple days. Link to comment Share on other sites More sharing options...
rtbrjason Posted June 20, 2013 Share Posted June 20, 2013 Pulling the rom in newer canbus cars does reset the ECU. Afterwards, you need to let it idle for 5ish minutes without touching the accelerator, or you will have rpm hunting going on for a day or 2.. Link to comment Share on other sites More sharing options...
Qckslvr Posted June 20, 2013 Author Share Posted June 20, 2013 Pulling the rom in newer canbus cars does reset the ECU. Afterwards, you need to let it idle for 5ish minutes without touching the accelerator, or you will have rpm hunting going on for a day or 2.. So at this point, assuming this is what is occuring, do i now let it idle for a while, or do i "reset" it again, and then let it idle, or....? Link to comment Share on other sites More sharing options...
Spec B Posted June 20, 2013 Share Posted June 20, 2013 Just reset the ecu while the car is fully warmed up. Restart and let it idle for 2-3 min, then do a few part throttle runs. What happens is your IAM drops after a reset - ECU needs to make sure there is no knock before giving you full timing advance. Easiest way to do this on my car is 40% throttle runs. Link to comment Share on other sites More sharing options...
Qckslvr Posted June 22, 2013 Author Share Posted June 22, 2013 Just reset the ecu while the car is fully warmed up. Restart and let it idle for 2-3 min, then do a few part throttle runs. What happens is your IAM drops after a reset - ECU needs to make sure there is no knock before giving you full timing advance. Easiest way to do this on my car is 40% throttle runs. Is there is a quick easy way to reset the ECU, or should I pull the ROM again? Link to comment Share on other sites More sharing options...
fahr_side Posted June 22, 2013 Share Posted June 22, 2013 RR Logger can reset the ECU, as can Learning View. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
