SurlyOldManMN Posted February 26, 2013 Share Posted February 26, 2013 I'm looking at a 2000 outback that has the head gasket, timing belt and water pump already serviced. Apparently routine maintenance is unheard of, this is the first one I've been able to find that has these things done. The problem is it "sometimes slips into 1st". I can't pin down a solid answer as to how likely it is that a fluid flush would solve this issue. In other words, how likely is it that I'd be buying a transmission about to pop? Link to comment Share on other sites More sharing options...
