05-09 5mt transmissions the same?
05AWDGT
The transmissions are all about the same from 05-09. There were slight changes in synchro style, the later transmissions being a bit more robust, but gears are all about the same width.
The only difference between the OB and the LGT transmission is the final drive. It's got a 4.44 vs. a 3.90. The shorter final drive (numerically higher) makes the OB trans inherently stronger, however.
With any OB trans, you'll also need the OB rear diff.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
I may be wrong but I thought the 05 was the only year that had the 4.4 ratio? :confused::confused:
As far as I am aware, all 05-09 OBXTs have a 4.44 with the LGT ratio gearset (the 3.166 set). The N/A OB has a 4.11 and shorter ratios (the 3.545 set).
I assumed we were talking about An LGT trans, and so I was only talking about the XT trans. I should have clarified.
yeah and LGT had 4.11 not 3.9. the WRX has 3.9 buddy
How about you spend more time doing research, and less time trying to be a condescending know-it-all, buddy.
First, not all WRX's have a 3.9. The ones with 1.1:1 transfer gears have a 3.70 front diff.
Second, only the 05-07 LGT has a 4.11. The 08-09, the one I looked up, has a 3.90.
http://www.cars101.com/subaru/legacy/legacy2009.html#mechanical
To the OP, it looks like the only bolt-in for you, would be a 05-07 LGT transmission. Everything else would require a different rear diff, or a rebuild to swap your front diff into the new trans (or their shafts into your trans).
The latter options are likely going to cost more than ordering a replacement for whatever broke and getting it fixed.
07's had the 4.11. 08+ had the 3.90 from what the OM's say.
http://www.cars101.com/subaru/legacy/legacy2007.html#mechanical
It could have been a poorly documented split year change, like Subaru did in 03.5 with the WRX.
I knew I saved this spec for a reason.
2.5 Turbo 5 Manual1st 3.4542nd 1.9473rd 1.3664th 0.9725th 0.738Reverse 3.333Transfer 1.000Final 4.444
Outback XT Manual 5spd1- 3.1662- 1.8823- 1.2964- 0.9725- 0.738final 4.444
The first trans you list is for the Forester XT.
No 05-09 MT LGT came with a 4.444 FD.
Oops. Your right. copy and pasted the wrong one. Lets try this again.
Legacy GT Turbo Manual
5spd manual
1st 3.166
2nd 1.882
3rd 1.296
4th .972
5th .738
final reduction 4.111
1- 3.166
2- 1.882
3- 1.296
4- 0.972
5- 0.738
final 4.444
2.5 XT Turbo 5 Manual
1st 3.454
2nd 1.947
3rd 1.366
4th 0.972
5th 0.738
Reverse 3.333
Transfer 1.000
Final 4.444
Here's the million dollar question, will a 06 wrx 5sp drop in a 05 lgt? I know the rear gear would have to be changed. But I can get wrx reman for cheap from a local guy.
It should.
The starter mounts the same, and both use male axles. The output shaft is the same spline count, too.
The WRX trans has a speed sensor you won't use, so don't worry about that.
You would need a WRX rear diff, too.
Rallispec has put out an awesome chart
Transmission ID Chart_Public.pdf
is the file name that I found it under, but I have been searching around for it online again, and have not been able to find it.
So, the 2005LGT has
TY757VBAAB-a 5 speed transmission, with an open front diff, 1:1 center diff, 4.111:1 final drive
and
27020AA050-a R160 w/ Viscous
and the 2006 Impreza WRX has
TY754VW7AA-a 5 speed transmission, with an open front diff, 1:1 center diff, 3.700:1 final drive
and
27020AA050-a R160 w/Viscous
if you want a copy of the chart, is is emailable, or i can send you a link to it on my google docs, shoot me a PM
It should.
Cool, that's what I thought, but I wanted to make sure.
